Leaking Holley carb - Help |
brittcrowell
Groupie Joined: May-23-2005 Location: United States Status: Offline Points: 64 |
Posted: July-16-2012 at 7:55pm |
Just rebuilt my Holley carb on my '93 ski.
After about 6-8 of turning it over and getting the carb primed it ran just fine. Then I noticed the leak. Its coming form the metal plugs on the front a rear bowls, 3 of the 4 are leaking/seeping when the boat is running. What is the right way to fix this besides buying new bowls. I had a friend with a shop dip the carb, so maybe that messed things up by removing some kind of glue or sealant? HELP! Please. Thanks, Britt |
'93 Ski Nautique (needs new interior)
MI-nick
Gold Member Joined: January-12-2009 Location: Ypsilanti, MI Status: Offline Points: 809 |
let it sit with the bowls full of fuel and try it again...it may stop leaking (i think the plugs or sealant swell a bit)...mine did.
f not, some jb weld may work...new bowls will definitely work. seems i've seen this problem posted (including me) about 5 times this year... |
As far as I can tell, I'm not quite sure...
Patman79
Groupie Joined: June-26-2012 Location: Bertram TX Status: Offline Points: 85 |
Mine were covered in JB Weld when I got the boat. I wondered what that was all about and now I have a pretty good idea! I just bought a "new" rebuilt carb last week and it gets here tomorrow!
Patrick
MI-nick
FYI, Kris (Big Pappa) had the same issue with his '85 and it stopped leaking after sitting a bit with fuel in the bowls...
C-Bass
Platinum Member Joined: November-18-2008 Location: Columbus, IN Status: Offline Points: 1248 |
I had the same issue as well. I performed a JB Weld fix and it hasn't leaked since. I didn't wait to see if it would fix itself as I was leaving on a boating trip and didn't want to take the gamble.
brittcrowell
What did it take to get the plugs out? |
No need to remove anything. A dab of jb weld at the seam will seal it up. This seems to be a common problem. Ive had to do on several different boats. Havent had one start leaking afterwards yet.
brittcrowell
Well I just confirmed it sealed itself up over night with gas sitting in it.
Thanks for all the support guys. Britt |
MI-nick
nice!!
kapla
been there, done that!
<a href="">1992 ski nautique
