Temperature Light on a 88sn |
pumpdad
Newbie Joined: February-27-2008 Location: United States Status: Offline Points: 29 |
Posted: July-02-2012 at 11:46am |
Hey guys, I have a 88sn, the impeller and thermostat was changed last year. After that the light beside the temp guage started staying on. You can see the thermostat working, ranging from 140 to 170. I dont know why the light is on and wondered if you guys could help me out.
Thanks, Chad |
Chad Lankford
89Martinique
Senior Member Joined: September-05-2011 Location: Binghamton Status: Offline Points: 457 |
there is a little black box that reads all the senor readings. it must be going bad. you can just disconnect it unless you dont much attention to your gauges. the box in Our Martinique the wires that go into the quick disconnect for the box are falling out of their crimps. so i unplugged it.
and im sure by propeller you the impeller for rwp |
Current Boats:
1992 Supra Comp-TS6M PCM 351w HO Pro Boss Pro-Tec Ignition - Full Composite (no wood stingers!) 1989 (3rd Gen) Correct Craft Martinique B/R PCM 351w Power Plus 1984 E-Scow Keuka Lake, |
pumpdad
Yea I meant impeller, I went back and changed it. Thanks for the reply. So unplugging the sensor box won't effect the gauges, just indicator lights will not work?
Thanks, Chad |
Chad Lankford
89Martinique
yes. it will just stop the idiot lights and the buzzer from working. it wont effect the gauges.
i also recommend next time you buy an impeller buy a silicon one. ours has lasted over 15 years and been through a couple dry runs. they are only $30. well worth looking into. i have a link to find a silicon impeller for any engine. |
Current Boats:
