Engine runs cool |
rfarkash
Senior Member Joined: September-06-2011 Location: Plainville, MA Status: Offline Points: 116 |
Posted: June-27-2012 at 1:48am |
Contrary to most posts here regarding engines running too hot, mine seems to hover around 140 all the time. Maybe a bit higher at idle after running hard, but haven't ever seen 160. All new water lines, impeller, t-stat (143F), and temp sender over the winter. Anything I should be worried about (t-stat in backwards), or just count myself lucky?
Thanks Ron |
Ron 1989 Ski Nautique
89Martinique
Senior Member Joined: September-05-2011 Location: Binghamton Status: Offline Points: 457 |
if your t-stat was in back wards that engine would over heat very quick. t-stats just like most everything else have limits as to what is acceptable and what is not. they are not all dead on 143. my 143 keeps the boat right around 150. when my boat is warming up it gets to just over 160 then cools to 140 and comes back up to 150. So mine is roughly 5% within target temp. Yours is roughly 2%. I wouldnt worry at all. my uncle has a heat exchanger with a 160 and it never gets above 140. Even with a new t-stat.
Current Boats:
1992 Supra Comp-TS6M PCM 351w HO Pro Boss Pro-Tec Ignition - Full Composite (no wood stingers!) 1989 (3rd Gen) Correct Craft Martinique B/R PCM 351w Power Plus 1984 E-Scow Keuka Lake, |
89Martinique
also. never above 160 at idle after hard running is a very good thing. our Martinique was running WOT for over 20 min straight pulling a 3 person tube with three college guys in it and at idle the temp shot strait up to a little over 200. Had to rev it a little to cool it off for the next 25 min run at WOT.
Current Boats:
rfarkash
Great - thanks for putting my mind at ease.
Will just enjoy the boat this weekend :) Thx Ron |
Bri892001
Sounds like you're in pretty good shape to me.
Have you tried grounding the temp sender wire to the block to see if the gauge pegs? If it doesn't peg, you could have a gauge issue, but again, there is just some natural variation. |
mdvalant
Grand Poobah Joined: May-06-2009 Location: Bellevue, IA Status: Offline Points: 2059 |
Our previously owned 90 has ran 140-145 for 1500 hrs
