oil gauge |
bruce
Newbie Joined: March-09-2004 Location: Albania Status: Offline Points: 3 |
Posted: March-09-2004 at 9:07pm |
Just bought a 2000 air nautique with 65 hrs. Discovered the oil pressure gauge isn't working. Is this a common problem??? I'm unsure if its the gauge itself or the pressure sensor on the motor. Any ideas???
tryan
Senior Member Joined: November-12-2003 Location: United States Status: Offline Points: 345 |
is the gauge fed from the fi computer?
woodyelc
Senior Member Joined: February-17-2004 Location: orlando Status: Offline Points: 376 |
i would check with a machanical gauge first. most likely its the gauge very little problem with senders. another check is to take wire from the sender which is blue and turn keypad on and put blue wire to ground while you are looking at gauge, if it goes to 80 the gauge is good if not the gauge is bad. hope this helps.
woodyelc
bruce
Thanks, I'll check it out
