  New Posts New Posts RSS Feed - Hard starting
Hard starting
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Topic: Hard starting
    Posted: June-27-2005 at 1:33pm
WOT starts are usually an indication of a flooded engine. Immediately after you shut off a warm engine, remove the spark arrestor and look down the primary and secondary throttle bores. If you see fuel dribbling into the bores, you have a problem with the carburetor and your engine is being flooded. Usually this scenario is caused by improper float adjustment or trash in the needle valves.
Barr 68 View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barr 68 Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2005 at 9:19am
My 68 barracuda has a 318 chrysler with a carter afb. It requires you to move the lever to wide open to start the engine ,especially when hot. Any thoughts ,is this normal for this engine? Is it possible the choke is not operating properly? Thanks in advance,Jim
