Whats the right boat to buy? |
Revman
Guest |
Posted: June-02-2005 at 1:32pm |
Hello Nautique Fans, I myself have allways been
a Nautique Fan as well skiing my personal best behind a 93 Nautique. For the most part I Slalom ski but like to wakeboard and Barefoot. I would like to buy a brand new boat but the price tag on them is way over my budget so what I would like to know is what year of boat whould best suit the type of skiing I do? My friend has a 89 but I would like something a little newer. I also like the looks of the 97 models. Are the 93-96 models the same hull design? How do the 97's slalom compared to the 93's? Does Perfect pass require EFI? Thanks, Revman |
bkhallpass
Revman,
Based on your post, I assume you are looking at the 19.5 foot or ski nautique hulls. How old of boat depends upon your ability/tolerance for working on these boats and taking care of them. Of the vintage boats you discussed, the hulls can be broken down as follows 81-89, 90-96, 97-99. 81-89: The SN2001. Good waterski wake, however a little hard. First of the "larger" Ski nautiques. This boat is well liked by wakeboarders because it can be weighted down to produce a very good, or even excellent wakeboard wake. 90-96. Ski nautique with the Euro style tail. There is a noticable step up in the waterski wake. It has less spray and is softer. Weighted down, this boat can put out a decent wakeboard wake, but not as good as the previous vintage. In 93, CC began the composite stringer system This means that there is no wood in boat. Personally, if I were looking at one of these boats, I would get a 93 or later. I can't recall when Fuel injection began, but I believe it was 94. Cosmetically, they changed the striping almost every year, added built in stereos, changed the windshield, etc. but not much differnce. 97-99: This was the first era of the Total Surface control Hull. This is a modern, world class waterski wake. Boat handles unbelievably. EFI was not standard, but most came with EFI. Even weighted down, this will produce the weakest wakeboard wake of the three vintages you have mentioned. Check out the references section of this section. There are sales brochures from a lot of years which can help you understand the progression of features, etc. Hope this helps. I'm sure others will pipe in with distinguishing characteristics betwen these boats. BKH |
Livin' the Dream
SGY
Guest |
I agree with everything Bkhallpass stated except that the TSC1 hull went from 97-2001. 2002 was the first year for the TSC2 hull.
IMHO, there is a big difference between the 2001 model wake and the 90-96 model wake. Much softer and smaller. The TSC1 hull improved over the 90-96 substantially. EFI started in 1994 but be careful buying this TBI powered boat. If they are "right" they run like a scalded dog. If not, you will be in for some problems. Contact the folks at PCM for more info. I'd look for a 95-96 GT-40 for that vintage or a 97-2001. You won't be sorry if you buy the TSC hulled boat. Awesome. |
