  New Posts New Posts RSS Feed - Exhaust mani gasket
Exhaust mani gasket
JoelH View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoelH Quote  Post ReplyReply Direct Link To This Post Topic: Exhaust mani gasket
    Posted: May-30-2005 at 1:56pm
I need to replace the exhaust manifold gasket on one side, between the manifold and the head. I did this last year on the other side of the engine but ordered the whole side gasket, bolt, etc, kit from SkiDim. I'd rather just replace the 3.00 gasket on the other side this time- is this something that can be picked up at an auto parts store, and what should I ask for? I think the shipping at ski dim is actually more expensive than the gasket!
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoelH Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2005 at 1:57pm
Oh, and the boat- 90 SN, 351.
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2005 at 2:25pm
If FelPro makes it, it is OK to use. If they do not make it, use a gasket they do. My 2 cents.
Check to see if Felpro has a Marine gasket for that engine. I suspect they do. I have found tech support at FelPro easy to get in touch with. You should call them and get their part number for the gasket you need. Shop it.
Although, many on this forum probably know the part number.
