Boat dilemma? 206 VS 216 |
philippebt
Newbie Joined: October-12-2009 Status: Offline Points: 2 |
Posted: October-12-2009 at 10:39pm |
Hi,
I'm looking to buy a used nautique and I want to have your opinion I found 2 boats: - A 2006 - 216 with some option in (tower, perfect pass, heater …) and it has 300 hours on, for $35,000 - A 2009 – 206 with everything + (tower, zero cruise, heater, tower speaker tower, hydrogate sport shift …) and it has only 30 hours for $40 000 Does the 5000 of difference worth it? I’m looking for a slalom boat first, but we do wakeboard and wakesurf too What do you think? Thanks Philippe |
SN206
Grand Poobah Joined: February-25-2009 Location: Fort Worth, TX Status: Offline Points: 2339 |
I would jump on the '09!
bkhallpass
Going to be very difficult to wakesurf a 206 -dangerous in my opinion. 206 is a much better slalom boat, however. 206 is also more nimble in its handling.
216 is a very good, not great slalom boat. Good not great wakeboard boat. I have seen guys surf the 216. Would make me nervous to load it up that much, but I've seen it done. BKH |
Livin' the Dream
SN206
Which motors do they have? I'd consider the longer length of warranty that you'll have w/ the '09.
emccallum
Platinum Member Joined: August-08-2006 Location: Clarks Hill SC Status: Offline Points: 1084 |
A buddy of mine just got a 2005 air nautique 206 with 550 hours for 23k. Boat was in good condition. Not sure the new ones are built quite as well as the old ones. It was on ebay and didnt get any bids, and the guy really needed to sell it. I think he took a beating as he only had it for two years. There are some deals out there, dont be afraid to lowball.
SN206
Was it a Air Natique, or was it a SN206 w/ the "AIR" graphics. Big difference in the hull. |
emccallum
I am pretty sure it is a 206 with Air graphics and a Flight control tower. I do know it has a GM motor, walk thru bow, and ballast tank. My apologies, I really dont know the post 2000 boats very well! I can find out for sure if you want to know.
There was no such thing as an "Air Nautique" hull in '05... it was just a graphics package. They offered it on everything from the 206 on up. |
emccallum
hahaha, I was right by ignorance!
philippebt
the 216 i'm not shure about the motor i have to check back in my file (I think it is a 330 PCM) but the 206 is a 343 PCM ex 5.7 liters
Is it a good motor (the 343)? it will be my first ski boat I just sold my bayliner 185! so it will be a huge upgrade! Thanks for your answers!! |
quinner
The 330 and 343 are pretty much the same motor, both are the Excalibur's 350 Chevy Block w/EFI, they bumped the HP up in 06' or 07' with some mods.
I am with TRBenj on the above, all 206's have the same hull, TSC 2 or 3 depending on year, believe the same would be true with the 216 as well. Have about 300+ hrs on my Excalibur, so far so good! If it was me I would be all over the 206 after pounding them a bit on the price. |
Fl Inboards
Grand Poobah Joined: January-20-2008 Location: United States Status: Offline Points: 2065 |
Dont think that Ballast was ever offered with a 206. The 206 has the same hull bottom from the steering wheel back as the 02-05 Ski Nautique . From the Steering wheel forward is where the 206 got it's length.
The 206 is a very nice slalom boat provided that it is with out a tower, Start adding towers and racks and speakers it becomes a good family all around ski boat. The 216 has rather large wakes for slalom and small wakes for wakeboarding. It is another run of the mill nice inboard boats but does not have anything but adaquate wakes for skiing or boarding. |
emccallum
According to the reference section, in 2005 they offered a 206 Air Nautique TSC2 hull with a tower and optional ballast. that is what my friend just purchased.
http://www.correctcraftfan.com/reference/2005_brochure/index.asp?page=28 |
behindpropeller
There is a nice 206 with ZR6 on PN for $27K. Tim |
quinner
Actually Jody the 206 was available with ballast, believe they really refer to it as a trick tank, single tank of about 200lbs, the 216 was available with (2) tanks of about 200lbs each.
The 206 tank is in the trunk so you lose about half the depth of the trunk area when equipped with a tank. No question the 206 is weight sensitive, with regards to the slalom wake, ours being the "heavy" version we typically try to carry minimal fuel and only 1 passenger whenever slaloming for the best wake. |
Fl Inboards
Yep! Your right! I remember that now! It did not do a whole lot as we were trying to quell the trickers as they were on the war path over the crappy trick table that the 196 and 206 produced. I still have the T-shirt with the target on the back from the 03 Nationals!!!LOL |
emccallum
Quinner,
off topic a bit, but haveyou had any problems with the speed sensor in your 206? The speedometor in my friends wasnt working and I narrowed it down to the sensor itself. Ordered a new one ($80). All tests seemed to point to a bad sensor. What prop are you using? Thanks! |
quinner
Is your friends a Team or Limited edition? If so the pickups read into the Faria gateway box in the trunk which digitally sends the speed to the gauge. Believe a Signature may be different. Have not had a problem other then I would recommend if he has a gateway box to disconnect the pitot lines at the gateway to ensure they drain when winterizing, they are supposed to self drain however they did not the first year I put the boat up and the water transferred into the circuit board and fried it. Still running the factory 4-Blade 422, the only other I would consider is the 3 blade, which I think is a 470??
Did your friend buy the Red 206 out of Alabama? |
emccallum
Yes, he bought that boat. Do you know any history on it? The aligment was off and I think it needs a new prop. Otherwise it appears ok. We are going to put my 470 on it and see how it runs. This boat doesnt have pitot lines. It has a thru hull paddlewheel sensor that mounts right around the front drain hole. I dont know if it is team or limited.
SN206
My 09' Team 206 has the tower and produces damn near the exact wake as the 196 if someone sets in the back, but again 40K for an '09 sounds good given certain options.
