  New Posts New Posts RSS Feed - Float Switch Doesn’t Float
Jason View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jason Quote  Post ReplyReply Direct Link To This Post Topic: Float Switch Doesn’t Float
    Posted: April-20-2005 at 5:29pm
My float switch on my bilge pump, doesnt float when in water. I can manually flip up the switch and the pump starts, but it will not "float up" when water is in the bottom of the boat.
Is this a common problem? Easy fix? or just buy a new switch? Didnt really want to waste everyones time on a simple questions, but thought it might be a common problem that can be remedied.
thanks
skyhawkflyer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skyhawkflyer Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2005 at 5:43pm
Some installations have the switch mounted on the pump (one unit), but if yours is mounted separetly just replace the switch. They are fairly inexpensive.
hyper1685 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hyper1685 Quote  Post ReplyReply Direct Link To This Post Posted: April-21-2005 at 1:48am
Sounds like you have water in the float it self. take the float out and drain it, and then reseal the float.
Chris
nate78ski View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote nate78ski Quote  Post ReplyReply Direct Link To This Post Posted: April-21-2005 at 8:41pm
Just replace the float switch.
