prop nut |
hyper1685
Groupie Joined: September-08-2004 Location: United States Status: Offline Points: 57 |
Posted: March-18-2005 at 3:43pm |
I just ordered a ACME 540 prop for my 86 SN 2001. When i put the new prop on, how tight does the prop nut need to be?
thanks for your help chris |
Morfoot
Grand Poobah Joined: February-06-2004 Location: South Lanier Status: Offline Points: 5311 |
My experience has been to hand tighten it as tight as you can then use a wrench to tighten it to the next available position where you can install the stainless steel cotter pin.
Tim D
Tighten until the cotter pin will go through. When you spin it in the water it will work its way up the tappered shaft and will have to be pulled off with a puller.
Tim D
hyper1685
thanks a bunch for the replies guys.
chris |
GottaSki
Guest |
Debur the keyway, then
Lap the prop to the shaft with compound, until the contact patch is at least 2/3 of the bore. Then mark the shaft with a sharpie how far the prop seats on the shaft. Now add the key, and the prop better seat at the same position, else the keyway is binding.. Don't draw the prop/keyway on with the nut, get it to seat before torqing, and there will be zero err and vibration from installation. The lapping will also make the prop easier to remove later because the strain is distributed evenly throughout the taper.. |
hyper1685
i got the prop today! what should the torque be if i use a nylon lock prop nut(without cotter pin)
thanks chris |
tdkosta
Guest |
I don't know what other boaters have done, but I would use a different nut that will let you also use a cotter pin. The nylock prop nuts are used on propshafts that have an eyelet at the end for a cotter pin to be used.
mackwrench
Senior Member Joined: February-25-2005 Location: Gone Status: Offline Points: 190 |
I hope it goes w/out saying ,,, make sure it's a stainless pin
NO LONGER A MEMBER
82tique
Senior Member Joined: June-04-2004 Location: United States Status: Offline Points: 339 |
Use a cotter pin!
I lost a prop by just using a lock nut last summer. It's a sad feeling to be stuck out on the lake knowing that your $350 prop just sank to the bottom. Needless to say... you live and you learn....that day I learned why God made cotter pins. |
David F
Very few people take the precaution to only use nylock nuts once. After they are initially installed, they never hold quit as tight. Some things that is okay, but with props not so good. I tend to agree that a castle nut and cotter pin is the safest choice.
jameski
Senior Member Joined: May-18-2004 Location: United States Status: Offline Points: 368 |
I had a problem the last time I changed props. when I tightened the castle nut it came up way short of the cotter pin hole. I couldn't torque it enough to get it to the hole (or at least I didn't think I SHOULD torque it that much). But if I loosened it enough to hit the previous hole, it was too loose. So, I went with a nylock. I would really rather go back to the castle nut, but I don't know how to get it to line up. I guess I could use a flat washer to shim it? Any suggestions?
David F
If you use the nylock nut, is the cotter pin hole exposed? If so, install the cotter pin so that in the event the nylock nut does not hold at least you will not loose the prop.
I cannot see any harm in using flat washer(s) to shim a castle nut closer to the hole. |
Morfoot
Sure, I'd use a washer to shim it up so that u can get a snug fit. It works on airplanes why not on boats. I would use stainless so that it wouldn't rust.
hyper1685
thanks for the help guys. i just reused the castle nut and cotter pin that was holding the old prop on. i will keep the nylon nut with my spare prop in case i need it.
Chris |
David F
For more information go here
