!!!Project 80 Ski!!! |
Post Reply | Page 123 6> |
MarineSRT8
Senior Member Joined: August-06-2007 Location: IN/FL/SC Status: Offline Points: 227 |
Posted: September-01-2007 at 1:40am |
Im almost all the way through the tear down proccess right now. Tomorrow I will be washing out the hull and prepping everything for the "beast" to go back in. Heres some of what Ive captured so far. I have no one to be snapping pics while Im working so forgive me if there are gaps in the progression of pictures.
There a little charred but its all at the machine shop now. These are all my goodies so far....More to come!!! |
"Some people go an entire lifetime wondering if they made a difference. Marines don't have that problem"
-Pres. Ronald Reagan- |
MarineSRT8
oops forgot this
87BFN owner
Let us know how the alum heads work out, there have been many posts here about them. Looks like you have your work cut out for you, but I am sure the end result will be sweet.
The Dude
I like it that the heads and others are set on the sofa for the all important pics!
Mullet Free since 93
95 Sport |
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6112 |
Quite a project!!! I think I'm doing good when I wax the boat and change the oil.
Good luck with it. |
MaddMarxx
nice stuff... I have to ask you one thing, is that a marine carb, if not take back before you use it, and get the right one!
MarineSRT8
yes it is the Holly 750 cfm Marine Carb....Thanks for looking out though
jbear
Dude; I liked it to that all the stuff was laid out on the couch...Mr. Marine must not be married.
john |
MarineSRT8
Nope....HAPPILY Single!!!!!
MaddMarxx
I like those heads, what did they set you back??
MarineSRT8
with shipping about 1200... they're only 1.90s. The 351W has notched pistons stock BUT I wasnt sure that it was a deep enough notch to facilitate 2.02s....So I played it safe. I have roller solid lifters, and roller rockers on the way. MSD ignition and Crane Fire Ball Coil.....Ive been trying to contact the doc about the Hi-Teks, someone posted about him getting a good price. Thats the next investment.
MarineSRT8
oh and by the way the ski lime is def one of the baddest SNs I have EVER seen!!!
backfoot100
Nate, looks like quite a project. Definitely keep us posted on the results. By looking at the cam, I would assume that you're converting this to a standard rotation motor?
Eddie |
quinner
Do Aluminum heads require a closed cooling system like the ZR6?
Good luck with your project, many new cool parts! |
I call that stuff gingerbread, watch the gear drive they dont like high RPM's
BuffaloBFN
If that's gingerbread, what's meat and potatos?!!? LOL
MarineSRT8
Its and 80 so the motor is already a standard rotation. CC didnt change that until 88 |
MarineSRT8
I think with the right setup the gear drive will do well. I helped a friend at home build a 383 stroker with a gear drive that achieved 450hp and will touch 8 grand if you want it to |
MarineSRT8
I read all the threads on heads before I made my purchase and it seems to me that I will be ok with raw water on aluminum heads. Especially if I flush the system periodically. And considering the limited # of times my boat will be on the water I think Ill be fine!!! |
bkhallpass
?? 80 had reverse rotation motors. BKH |
Livin' the Dream
BuffaloBFN
FYI only...my 79 was RH and so is my 88; Did they put LH motors in 'em back then?
bkhallpass
Now your question kind of confuses me. A Standard Rotation Boat - Spins left (counterclockwise) when looking at the the prop from the back of the boat. - Spins right (clockwise) when looking at the flywheel from the front of the boat. A Reverse Rotation Boat - Spins right (clockwise when looking at the prop from the back of the boat. - Spins left (counterclockwise) when looking at the flywheel from the front of the boat. BKH |
Livin' the Dream
BuffaloBFN
Not my intent!
I understand RH and LH...you guys cleared the terminology up for me a while back However it's put, both my boats were RH...opposite a car...clockwise facing the stern Backfoot asked if he was converting to standard rotation. I took that to mean going from RH to LH. I asked because I thought all of the older CC's were RH. |
boat dr
Get the camera out again, give us a good shot of the dist. drive gear or a shot of the prop.Either one will tell the direction ,LH or conventional/ RH reverse rotation.
Some the parts you have bought will work.The rear seal is specific to rotation,as is piston rotation.The cam is a LH, or convetional,and will not work with a RH or reverse rotation dist. The oil pump is the same for either rotation. Hope you did some research on direction before you jumped into this rebuild...boat dr |
BuffaloBFN
boat dr, again please pardon my ignorance...I understand the rear seal and cam being directional. I don't understand the piston rotation part.
Thanks |
BuffaloBFN
'79 is missing a field day here?!!? LOL
MaddMarxx
SRT8...Are you going to rebuild that motor or are you just going bolt all that stuff on that motor, because I have a new set 30 over, keith black pistons for sale if you need them!
MarineSRT8
The block is at the machine shope right now, and taking into account the shape of the cylinders and the pistons I will not have to do any boring at all. But if that situation presents itself I will keep you in mind. Guess I started quite a thread with the rotation comment. I know my boat is a standard rotation motor for sure. I hope I led no one in the wrong direction by the statement I made.
jbear
Figured you had to be single. You are taking on quite a job. As you can see...guys here love these threads...me too...I just don't understand what all you guys are talkin' about.
Being a Marine must pay well these days...as it should. john |
MarineSRT8
No the pay still sucks. My mother passed away a little over a year ago and left me some money, so I am going to name my SN after her. I purhcased the boat on exactly the day she passed away. See she taught me how to ski when I was little and she was an amazing skier herself. I figured its the only way for me to spend time with her now that she's gone.
