Hi Teks ,,Worth the Hype or Waste ? |
Page 123> |
the goose ![]() Newbie ![]() Joined: March-30-2007 Location: Canada Status: Offline Points: 12 |
![]() ![]() ![]() ![]() ![]() Posted: August-25-2007 at 4:30am |
Recently came across some money that can be used on the boat, thinking of getting the HI Tek manifold /riser often spoken of by the " Boat Dr".
I have also seen some negativity towards them here on this board.Saying that they are simply not worth the money My question is simple,,,, If you had the money would you get them ? ,, and if you already have them did they really make that much of a difference for the buck. I want to " steer" my boat away from stock and spruce up the motor the hi teks seems like a good place to start Looking forward to your comments Regards The Goose ![]() |
stang72 ![]() Platinum Member ![]() ![]() Joined: July-31-2004 Location: United States Status: Offline Points: 1608 |
Goose...I can't comment on the performance , however , they look bad to the bone! The looks alone almost justify the price...if the performance is a plus...yeah...go for it!
Oh yeah..one more thing! They are quite nicely polished...so you won't have to spend time keeping them shiny....that time saved can be well spent somewhere else
MaddMarxx ![]() Platinum Member ![]() ![]() Joined: June-29-2006 Location: United States Status: Offline Points: 1741 |
The 1500 dollar question! If I had a stock motor and 1500 bucks to spend, I would get a set of heads an intake a cam and a new prop and I would still have 500 bucks left to take my gurl out to dinner with...but thats just me.
Good luck with the, Hi-price-teks! ![]() |
MM....dinner and then the hilton hotel and maybe she would even invite a friend,
The hi-teks are like the icing on a cake, you take care of everything else performance wise and mechanically, then you top it off with the hi-teks, dollar for dollar on the performance end you go after engine up grades and if you have money left over you install some hi-teks, you dont want to install these on a tired engine |
Thanks Maxx and Eric,
I am not sure if my engine is quite tired "yet". The compression is great on it still and it runs strong,, I am interested in the heads,,, those would be the gt40 "p" version people are taking about? Cam sounds good as well however my access to a mechanic with marine experience is proving difficult to find, could I use someone whom specializes in automotive rebuild ? Thats why the hi techs were a big consideration for me as they were/are considerably easier install. BTW the prop has already been upgraded by the boys at acme, great fellows there. Thoughts Thanks in Advance The Goose |
goose,I was the one that put the Hi-Tek deal together,my reasoning was more for the weight than the HP,12 lbs. VS 44 lbs.That was in itself cost effective, how much did it add to my 331 ,don't know!!!!!
MM has a good point ,do the cam,heads and intake first.Then finish the job with an exhaust system. Do a search on Hi-Tek and you will find pics and info to help you make a sound choice. 87BFN gained 400 rpms with a set plus a ignition upgrade.Intake,heads,and a good cam may not give you that. I have no regrets, and would do it again, the painted ones are cheaper. Polished was the way I wanted to go,my stroker deserves the very best, Ask anyone that was at Green Lake how the old girl was running , and I had carb issues that was just recently sorted out.She will pull a 12x14 OJ 5100 rpms........ Idle to 40 in 6 seconds Idle to 50 in 8 seconds Too fast for an old boat that was only ment to go 40.................boat dr |
87BFN owner ![]() Grand Poobah ![]() ![]() Joined: August-25-2006 Location: Ypsilanti, MI Status: Offline Points: 2194 |
Goose,
My BFN had 1380hrs on it when I put the hi-teks on it. They definitely woke my 454 up some. I have plans of doing the whole motor in the future but the for right now the hi-teks were thew better route due to the price the boat doc got us. If I were you I would put the money in cam, heads, and intake. Then do the exhaust later when you have some extra money to spend on the boat after those upgrades. |
BD you get that trans in yet?
'87...got a pic of those teks?
do a search on hi-teks , there are some good pics on them
I wanted to see 'em on his 454...I've seen the Boat Dr's and the custom install TRB did...very nice
BuffaloBFN,
I will get some up tonight or tomorrow night for sure. I have some other pics that need to be posted as well... |
69 Mustang ![]() Senior Member ![]() Joined: April-26-2006 Location: United States Status: Offline Points: 402 |
Boat Dr.
I'm doing 0-40 in about 8.5 seconds (stopwatch and GPS) in a 78 SkiTique with a full tank and 2 people. Original 302 (800 hrs) and a new OJ 12x13, only other mod is electronic ignition. Not bad, I guess? Mike |
For every complex problem, there is a solution that is simple, neat, and wrong.
"Where the **** are we?" Amelia Earhart. July 2, 1937 |
Speed can be costly,worst drug known to man.Just say NO....boat dr
Like others have said, money is much better spent on heads and a cam. You can do those for less than the cost of the Hi-Teks, and they will make a bigger difference. I added the Hi-Teks last, as they were the only remaining piece of the puzzle to let my engine breathe. Since you already have a GT40, Im not sure if there are any intake upgrades you can do. The GT40 heads arent too bad either (the P's wouldnt give enough of an advantage to justify swapping them out). I would consider getting a cam and installing roller rockers first. Do the Hi-Teks really make that much of a difference? With the exhaust and roller rockers (which I did at the same time), I gained ~400 RPM in holeshot and ~300 RPM at WOT. Do they really make that much of a difference for the buck? Only you can answer that. |
Goose , have to agree with Tim on all the above ,except the roller rockers.Do not see the need nor the power increase to justify said expenditure.
Maybe because he has them and I don't,there goes that male penis envy thing again... The only person that was in on the group purchase that has not commented is Reid. And I will speak for him; His feedback was not a positive as the other three, he says he lost a little power and some of his upper rpm's.Not being negative towards the product , just did not work well with the package he is running. Reid will you bring us up to speed on your Mustang project and how they have performed likes or dislikes..........boat dr |
I dont think I would buy them new, Doc- $300 is a steep price for 15hp. A good set (FMS/Crane, Scorpion) can be found used for $125-150, in which case I think theyre worth it (obviously). Id also like a set of aluminum underdrive pulleys, but Im having a hard time justifying the $200+ pricetag on those as well. I only recommend the RR's for Goose because he's already got a 310hp MPEFI motor. The heads and intake are already pretty decent. A cam and the RR's would have him pushing 340-350hp. Of course, a prop would be at the top of my list, above any of the aforementioned upgrades. |
reidp ![]() Platinum Member ![]() ![]() Joined: December-06-2003 Location: Mooresville, NC Status: Offline Points: 1804 |
Ok, I'm here to comment but unfortunately like Doc said I'm still a little neutral. I was rushed to get them on, and installed them on the engine for the first start up of the year. The engine obviously was in need of a complete tune-up. A difference in my case from the others was I was replacing an already decent set of aluminum manifolds with 4" risers and ported runners (as far as I could reach). I also made no attempts at further tuning gearing directly towards a more free-flowing exhaust. While they are no longer/currently on the blue '69 Mustang I originally planned them for, I will be installing them back on that boat or another very soon. I will certainly report results from that.
Still wondering if those hiteks would do anything for my rig as well. At this point the money doesnt mean a thing, unless they don't make any difference then the money hurts a lot. Somebody should just buy a set and rent them out to those that want to try before we buy..
Excellent idea Joe. I think Billy has that extra set sitting at his shop. How about it Doc? |
Joe , that is a good idea,Allen will be more than willing to sell you a set at full retail.If they do not work you can rent them out for week-ends,or maybe for summer vacations.
The possibilities are endless, the money as you said matters not. Allen, wants this set shipped to Miami for the boat show in October.Sorry I can't help with your R&R Joe........boat dr Just bite the bullet like we did Joe, after all it's only money......... |
BuffaloBFN
Here are a few shots of the hi-teks on m BFN. If you want better pics let me know as these were install pics and a couple quick shots from GL. ![]() ![]() ![]() ![]() ![]() ![]() |
68sklylark ![]() Newbie ![]() Joined: February-20-2007 Status: Offline Points: 6 |
Boat Dr.
I spoke with Allen earlier this year regarding HiTeks for my Skylark. We blew out the original aluminim maniflods once we go it running this spring. I found some cast iron manifolds but the dump tubes are wrong on them so now we are back to needing new manifolds. Will you please contact me with any information regarding arrangements you have with him. Thank you, Keith McIntyre ksmcintyre@centurytel.net 586-531-5513 |
87, thanks...and don't you wish they'd standardize the color stripe on the wet exhaust hose?
BuffaloBFN
That would be nice, as my supply hoses have a green stripe and the exhaust have a blue stripe. If you could get all the hoses you needed from one company they would have a better chance at it I bet. |
decisions, decisions...waste good hose and have 'em match or be frugal?!!? LOL
Your Teks look gooood! though maybe a little smaller on the BB...they'll be the last thing I do 'cause I have at least one cylinder that misses w/o the lead sub in the gas ![]() gotta fix my foundation first! |
I thought about the motor first, but I knew I wanted them and the price was right at the time. Now the way it runns with the upgrades I can hold off on redoing the motor for another year or so. This winters plans are new interior, new trailer, and redo the stripes and decals.
85nautiquematt ![]() Groupie ![]() Joined: August-07-2007 Location: United States Status: Offline Points: 58 |
A nice roller cam and full roller rockers would help free up some rotating friction and give a noticeable boost in power. There is a lot of drag at the lifter to camshaft area. It works well in street cars with noticeable results. Sounds like a good winter project.
Nothin like the sound of a mid 80's Nautique at mid throttle.
Good luck finding roller cam blanks for reverse rotation motors. I know they dont exist for the SBF, not sure you'd have any more luck with a BBC. |
Page 123> |
