whining noise |
hyper1685 ![]() Groupie ![]() Joined: September-08-2004 Location: United States Status: Offline Points: 57 |
![]() ![]() ![]() ![]() ![]() Posted: April-12-2005 at 7:40pm |
i have a whining noise coming from the boat usually when i turn, but not always when i trun. i ran aground the other day. had to replace the prop because of it. could it be the driveshaft? shaft bearings? trany? trans fluid is on the low side; could the low fluid be the problem?
Thanks, Chris |
mackwrench ![]() Senior Member ![]() Joined: February-25-2005 Location: Gone Status: Offline Points: 190 |
yes
NO LONGER A MEMBER
kenny g ![]() Senior Member ![]() Joined: December-13-2003 Location: United States Status: Offline Points: 318 |
did you have a woman on board ?
kenny g
yes but she was making a different noise. anymore suggestions?
are you getting the same noise with the new prop ? it could be a cavitation noise in a hard turn.
kenny g
yes the noise is there with the new prop. the prop is an ACME 540. i don't think the prop is the problem. let me know if im wrong
thanks, chris |
anyone else have any suggestions?
Thanks, Chris |
