ProTec Ignition Swap |
Page <123 |
wkebrdr ![]() Newbie ![]() Joined: April-08-2024 Location: 64078 Status: Offline Points: 1 |
I searched around, but what spark plugs are you using since going to the DUI?
Bill
92 Ski |
malcolm2 ![]() Senior Member ![]() ![]() Joined: June-13-2010 Location: Nashville Status: Offline Points: 239 |
I will have to check. I don't remember off-hand. I will get back here and reply with that. It has been quite a while, and I will say that this change was fan-dam-tastic. No more hiccups, super quick starts. ZERO ISSUES.
Jonny Quest ![]() Grand Poobah ![]() ![]() Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 3032 |
Autolite 764 or 104 plugs. 0.055 gap with the DUI.
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 11266 |
Since this is your first post, nobody knows whether your engine has the standard heads or gt40 heads. So..........the bestest, most correctest answer is to use the same plugs that are in it now because there were different plugs depending on the heads used
1993R ![]() Groupie ![]() Joined: July-27-2005 Location: Hawthorne, FL. Status: Offline Points: 52 |
I just did this conversion on my 92 ski
Same boat as JPAss Everything installed easy and my distributor is positioned just like the photos TDC has been checked twice. Wires installed properly. Only issue is motor and starter are turning but no fire to plug wires Checked power to the HEI and it’s moves between 11 and 12 volts when cranking Checked my grounds seem okay Haven’t run new the power and ground wires to dash yet DEI said it sounded like the unit needed to be grounded and offered a suggestion on how to test it It didn’t change anything Any suggestions ? |
Where are you checking power to the distributor? At the (+) terminal on the cap
Is the tach terminal hooked to the boat's gray tach wire? Nothing else hooked to the tach terminal Silly question, but is the 3 wire plug from the distributor plugged into the cap firmly? All 4 connections on the ignition module under the cap connected?
rosconole ![]() Gold Member ![]() ![]() Joined: May-10-2008 Location: United States Status: Offline Points: 763 |
Just hold the wires together put your foot in a bucket of water and crank it. Let me know if you feel anything.
You got this thing making noises like a running engine yet?
Keno
I will be jumping in it tonight
Got tied up at work but have next 5 days off You may have solved it via the tach wire I don’t have it going directly to the HEI Will route it properly and hopefully she fires up It’s been pretty hot in FL so early morning late nights are only times to work on stuff and feel comfortable Would like to get back to skiing again Will keep you posted Thanks |
Update
Sorry for the long delay My boat is up and running strong and starts like it’s brand new again I did some extra work to get there I did replace the starter solenoid and both push button fuses I rewired everything in 10 ga including the tack wire and the power wire to the HEI Removed all non essential wires from harnes Refinished the old protect mount in black crinkle finish and loomed all the wires Install looks clean and factory Boat fired right up Only two questions 1) the electrical connections had a black silicon applied at factory to help water proof Anybody know if it’s a specific brand and type. I would like to reapply . 2) The timing is currently set at 10 BTC and 800 rpm. I want to adjust it . From what I’m reading it should be 12 BTC at 600 rpm at idle correct ? I plan on retiming the boat but will be sending the carb out for a complete refresh and want everything to be spot on Thanks |
I'd check the total advance at about 3500 RPM before doing anything, so you know what you have.
DUI likes to say that there's 24 degrees of advance at 3000 RPM the way it's shipped to you. Add that 24 to 10 degrees of initial and you get 34. It seems like numerous people around here get anywhere from 20 to 24 degrees added to their initial when they check, with a lot in the 22ish area. 34 plus or minus 2 would be a good total number to have depending on what octane gas you're using. So setting it for whatever initial gives 34 total would be a good start. You might be there now or have to advance it a little 600 ish RPM in gear sounds good for idle RPM Not knowing what connections you want to cover in black goop, I guess I don't really see the need I'd wait till the carburetor comes back before doing the timing and idle adjustments unless you just want to practice doing it
40 degrees of timing ??? are you trying to sell an engine as well?? A GT 40 perhaps .
Umm, Roscoe, maybe you need to clean your glasses or go brush up on your math skills or something.
Page <123 |
