  New Posts New Posts RSS Feed - GT-40 Suddenly Died
GT-40 Suddenly Died
MI-nick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI-nick Quote  Post ReplyReply Direct Link To This Post Topic: GT-40 Suddenly Died
    Posted: April-14-2023 at 8:27pm
Beautiful day...about ready to strap my board on...boat was idling fine then died suddenly. No stumble, no sputter...went from a smooth idle to dead and would not restart. A couple times seemed like it would almost catch, but nothing. I pulled a plug and verified I had spark. Tried to connect my code reader, but it would not initiate a test, so I don't really know what that means. Starting this thread while I dig into past threads and the service manual. Any advice is appreciated as always. '99 SAN with GT-40. ~1200 hours. Put the boat on the lift last friday. It fired up fine and ran fine last friday, saturday, sunday. Fired up fine today. Warmed up for about 5 minutes, idled to my start spot for maybe 10 minutes. Dead. Wont restart. Cranks fine. I'll also add that I can hear the LP pump run when I first turn the key. FCC filter was replaced last fall.
bwinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bwinn Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2023 at 8:55pm
I’d start with a fuel pressure reading at the rail.
JamoJones View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JamoJones Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2023 at 12:03pm
Kind of off your topic, but could you tell me how I find out if I have GT 40 heads or not?  I bought an '87 SN project that came with a rebuilt 351W from Marshall's Marine.  I have no idea what heads.  Still a Ford block.
Thanks...
Jamo
1986 Silver Nautique #49 of 82
1987 Ski Nautique 2001
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2023 at 1:35pm
Look at your heads for markings like the picture below.
3 bars would be gt40, (there were also some early gt40 heads with 2 bars)
4 bars would be gt40P
no bars, just smooth in that spot, would be standard cylinder heads
The markings are on the front and back of each head
Post Options Post Options   Thanks (0) Thanks(0)   Quote JamoJones Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2023 at 4:49pm
Thanks Keno...just checked, mine are standard heads...
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2023 at 7:03pm
Back to our regularly scheduled programming, how's that fuel pressure Nick?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI-nick Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2023 at 9:32pm
Spent a couple hours testing things today and I think it's the HP fuel pump. Here is what I checked.
 - New EEC-IV tester. could not get the ECM to enter test mode. same as with old tester.
 - Replaced both ECM/Fuel pump relays and re-tried the test. Still nothing. Jumped the STI to ground, still nothing.
 - Checked fuel pressure with key on, ignition on. 0 PSI
 - Depressed valve on fuel rail and barely a few drops came out.
 - Jumped STO to ground to run fuel pumps. HP pump not running.
 - Confirmed 12V at LP pump and 12V at HP pump with STO jumped to ground.
 - Confirmed FCC full of fuel.
Seems pretty cut and dry to me that the HP pump is my problem. I'm a bit bothered that I couldn't get the ECM to enter test mode, but I don't really know what that means. Thoughts?
winniskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote winniskier Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2023 at 9:50pm
Check the kill switch.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2023 at 8:00am
Seems pretty cut and dry to me too, since it has 12 volts supplied and it's not running Wink
Maybe there's a slim chance it's running and the little connector hose inside the FCC just plain fell apart............maybe however slim
I guess the FCC will be coming apart soon
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI-nick Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2023 at 8:22am
yep, that's my next step. I'm going to go ahead and order an new HP pump though. If it's simply the connection inside the FCC, then i'll have a spare. spare parts help me sleep good at night.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI-nick Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2023 at 8:40am
any thoughts on why I can't get the code reader to run the KOEO test?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bwinn Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2023 at 9:08am
yep, that's my next step. I'm going to go ahead and order a new HP pump though. If it's simply the connection inside the FCC, then i'll have a spare. spare parts help me sleep good at night.
Walbro has a hp pump available at a fraction of the cost just need to order a plug with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bwinn Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2023 at 9:19am
Walbro GSS340 $57 on Amazon currently
HiSport wiring plug harness connector 94-615 $6
Fuel filter RP080026 $33
Hope this helps
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI-nick Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2023 at 9:31am
well, it would have been if I hadn't already ordered Unhappy. oh well, i'm sure this will be helpful for others that need a new pump
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI-nick Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2023 at 5:33pm
well, I took the FCC bowl off this morning to find the power lead the HP pump disconnected. the spade connector was very loose so I squoze it a bit re-attached. 38 psi with key on. fired right up. Went for a quick ride before the wind and rain. cancelled my pump order. wish I would have checked fuel pressure friday night...i got hung up on the code reader not working and starting thinking worst case...
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2023 at 8:11pm
You get one of these
Now from one spare parts guy to another, you need to get the cheaper HP pump for a spare and a cheap LP pump to go with it, just to insure that you won't need them for a long time........but when/if you do they're right at your fingertips.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2023 at 7:18am
To Keno's point above when my '96 sport suddenly died the small black hose inside the FCC failed (~3/8 split) in it.  Replaced that and it was good to go
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI-nick Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2023 at 7:59am
i definitely have the FCC hose in the spare parts cupboard. going to look into that cheap HP pump for a spare. I have my old LP pump as a spare. it was still working when I replaced it, just not functioning due to being clogged up with junk. the BIG question is do I want to give Nautique Parts the $900 they want for a spare ECM?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2023 at 9:36am
It's all been gone over here before. Perhaps if you'd do a search....
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI-nick Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2023 at 12:05pm
the ECM question, you mean? I've gone over many of those threads previously. i think the ECM options are basically try to find a donor in working order, buy a similar Ford ECM and re-program or have it re-programmed, or buy one that's already been re-programmed (Nautiqe parts, GT40 Marine, Miami Ski Nautiques...maybe others?)? are there other options?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2023 at 6:43pm
Perhaps a search won't do a whole helluva lot of good right about now, since the Moates people closed the doors and retired in Nov of 22 and trying to get parts like the f3v2 chip (that the tune gets burned to and then gets put into the donor ECM) is probably kinda tough.
A price check in aisle 1 says that the price at NP is 1150, but you can get a 10% discount and gt40 marine is 999 and ol' gt40 Mikey is looking for someone to solve his lack of chip issue.
