Delete trailer prop guard? |
Page 12> |
DockDoc ![]() Senior Member ![]() Joined: February-17-2014 Location: Charlotte, NC Status: Offline Points: 476 |
![]() ![]() ![]() ![]() ![]() Posted: May-24-2022 at 12:39am |
By way of update… problem was solved by welding on some brackets and then installing some heavy duty nylon casters I found on McMaster. Had a mobile welder fabricate and weld up the brackets. They’re a lot beefier than they need to be and likely overengineered but they do the trick. I was worried the steel rollers might scar up my concrete garage floor hence the Nylon. Poly would be even better but much more expensive.
Now when I roll out of the garage the casters carry the weight for a foot or two. It’s barely noticeable from the tow vehicle and doesn’t make a sound or leave a mark. Win! Update thread https://www.correctcraftfan.com/forum/forum_posts.asp?TID=50631&PID=605407 |
1993 Sport Nautique
PCM 351w, no ProTec |
Hollywood ![]() Moderator Group ![]() ![]() Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13523 |
Y’all’s balls too high.period.
MrMcD ![]() Grand Poobah ![]() ![]() Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3778 |
Hollywood, you better call E Trailer.com and educate them. They call it a Drop Hitch Receiver and damned if the picture does not look just like your Ball Mount = Draw Bar
CORRECTION: Hollywood is correct: A simple google search does show Drop Hitch Receiver with a picture of the typical ball mount drop hitch like I stated but I am wrong. If you actually search Ball Mount it shows the part and is worded "BALL MOUNT exactly as Hollywood pointed out initially. The search feature gets you there using any combination of descriptions, receiver, ball mount, Hitch but the proper term does appear to be Ball Mount, I will update my vocabulary thanks to Hollywood. ![]() They do offer drop hitch receivers but those actually allow mounting a ball mount down lower, I guess for those super high lifted trucks using heavier steel to lower the ball mount location.
63 Skier ![]() Grand Poobah ![]() ![]() Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4293 |
I'm going to add wheels, love the way that install looks. I end up dragging and lifting the entire boat/trailer occasionally, no damage to the guard. Having said that, it's a pretty huge shear load without the wheels so I think adding them will make the prop guard much less likely to be damaged.
desertskier ![]() Platinum Member ![]() ![]() Joined: December-19-2006 Location: Az Status: Offline Points: 1118 |
I guess it depends on what trailer you have. My prop guard can handle the weight of the boat and trailer no problem. I use it as a jack point all the time. Mine is box steel.
92 SN - Owned since 93
agetech ![]() Groupie ![]() Joined: September-21-2020 Location: Mo Status: Offline Points: 40 |
I don't think wheels on my prop guard will support the weight of the boat, the trailer tires would be completely off the ground. The ability of the prop guard to carry that weight would be in question. You don't know the angle of my driveway.
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 11275 |
Since a picture is worth a thousand words or something like that, how about a few thousand words worth of pictures?
gun-driver ![]() Grand Poobah ![]() Joined: July-18-2008 Location: Pittsburgh, Pa Status: Offline Points: 4129 |
Hollywood being a ball buster
Airbags? Someones been watching too many episodes of "Texas Metal"
I feel for you.
I had an 8" drop hitch, but then the hitch drug with the weight of the boat. I also tried the 2x6 under the tires method which helped, but the I had lumber laying on the driveway.
Yikes that sounds like a huge pain! I’m really hopeful the drop hitch will solve the problem - although it creates a new problem because with the truck on the down angle of the driveway, the hitch gets too low for the trailer kickstand to reach it without bottoming out. Frustrating. |
1993 Sport Nautique
I had the same problem, angle of driveway caused the prop guard to drag. I ended up putting inflatable air bags under the leaf springs, 15" tires, and 6" drop hitch. I air up the springs before I pull into or out of the garage, lower the pressure before hitting the road. I was able to build some mounts for the springs that didn't require welding or drilling on the trailer.
Jonny Quest ![]() Grand Poobah ![]() ![]() Joined: August-20-2013 Location: Utah--via Texas Status: Online Points: 3032 |
Ultra Micro Steel Roller Wheels by Ultra-Fab https://ultra-fab.com/product/ultra-micro-steel-roller-2w-x-2d-1-pk/ Can also be purchased at Amazon or ETrailer JQ
Well you thought wrong. What receives what ?
Ball mount = drawbar Hitch = receiver |
I always thought the term for ball mount was Receiver?
It’s not just you
Yeah again because I'm an idiot and keep confusing "hitch" with "ball mount". My bad.
1993 Sport Nautique
Fixed the Amazon link
1993 Sport Nautique
That’s not a hitch.
1993 Sport Nautique
Linky no worky
1993 Sport Nautique
Where do you guys find adjustable hitches?
Your welds look better than mine. I am still working on that skill set. I have a frame to modify, will give me lots of practice.
Where did you find the grazeable rollers?
Thanks McD. Those wheels are one of the best mods I've done on the trailer. I have a fairly steep driveway, so the butt-dragger wheels are used many times during waterski season. I got real tired of the scraping and grinding of the prop cage and the marks left on the concrete. JQ
That looks bout perfect JQ. Nice work.
I fabricated a mount for the R/V type "butt dragger" steel roller wheel. I have one wheel on each side of the prop cage. The axle on the roller wheel has a grease zerk for lubrication. The location of the roller wheel is about 3/4" below the prop cage.
I also have an adjustable ball mount so that I can drop the trailer tongue fairly low to get the a$$ end of the trailer (and prop cage) up with additional clearance if needed. ![]() |
Ugh literally just finished this brand new garage!! Couldn’t convince the wife to move out to the lake so oh well |
1993 Sport Nautique
Sell house, buy a more boat friendly residence
My fault, I'm confusing hitch and ball mount... I'm getting an adjustable ball mount.
1993 Sport Nautique
Page 12> |
