  New Posts New Posts RSS Feed - Delete trailer prop guard?
DockDoc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DockDoc Quote  Post ReplyReply Direct Link To This Post Topic: Delete trailer prop guard?
    Posted: October-30-2021 at 6:36pm
New garage. Boat barely fits. Annoyingly, the trailer prop guard strikes the ground when backing in, because the angle of attack is down the driveway then back up into the garage. It needs about 1.5” extra height (blocked a 2x4 under the trailer tires and it cleared no problem). I removed the prop guard and the trailer backed right in, prop has plenty of clearance.
Think it’s a terrible idea to semi permanently delete the prop guard to facilitate garage parking? On longer trips or unusual destinations I could bolt it back on.
Other considerations - build some ramps out of lumber (works but a pain), buy bigger trailer tires (could work but not sure if they’d fit, also expensive and I’d have to buy 4 of them), lower my trailer hitch from a 4” to a 5-6” drop (could work but might negatively affect towing dynamics), store the dang thing outside.
1993 Sport Nautique
PCM 351w, no ProTec
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-30-2021 at 6:46pm
You've already done it and it works, so your plan sounds reasonable to me. Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DockDoc Quote  Post ReplyReply Direct Link To This Post Posted: October-30-2021 at 6:50pm
Deleting the prop guard? It definitely works, just not sure if it’s a dumb idea to leave it off all the time.
1993 Sport Nautique
PCM 351w, no ProTec
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-30-2021 at 6:52pm
Probably depends on how much ground clearance you have and if you go four wheelin' to get to the launch ramp Wink
desertskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Posted: October-30-2021 at 7:14pm
I know someone that welded a couple of small wheels to the prop guard to handle a steep driveway.  I think they did the job.
92 SN - Owned since 93
99 Pro Air
89 SN - Went to live on a lake in Texas
75 Donzi 16 - Sold in 93
scootdogydog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scootdogydog Quote  Post ReplyReply Direct Link To This Post Posted: October-30-2021 at 7:55pm
If you lower the bow, the stern will rise. 4-6" drop and you'll be fine
1999 Python
1980 Ski Tique
1968 Mustang WIP
Post Options Post Options   Thanks (0) Thanks(0)   Quote DockDoc Quote  Post ReplyReply Direct Link To This Post Posted: October-30-2021 at 7:57pm
That is an awesome idea. Could probably just bolt something on. Thanks
1993 Sport Nautique
PCM 351w, no ProTec
Post Options Post Options   Thanks (0) Thanks(0)   Quote DockDoc Quote  Post ReplyReply Direct Link To This Post Posted: October-30-2021 at 7:58pm
Yeah I’ve got a 4” drop already which keeps everything pretty neutral, but might try a 5-6” to see how that works. Certainly an easy fix. Maybe an adjustable hitch is in my future.
1993 Sport Nautique
PCM 351w, no ProTec
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: October-30-2021 at 9:23pm
Drop the hitch and see what it does for you.  I had to drop my nautique hitch to get more weight onto the front wheels of my trailer so the brakes worked properly, I have a 2 axle trailer.  I have towed with a variety of vehicles and have a collection of receiver hitches to use from straight to 6" drop.   I think if you remove the prop guard you will be un lucky enough to have your prop kiss something it should not kiss and you won't be happy.
I have seen wheels on the back of trailers many times to allow bad angles to roll on by.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: October-30-2021 at 9:32pm
RV's also weld on wheels for the same purpose. Bumper drag.
1968 Ski Nautique, Project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DockDoc Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2021 at 8:23am
Yeah this is the approach I’m going with. Ordered a drop hitch and will give that a go. If it doesn’t work I’ll pursue the roller / caster route which seems pretty straightforward. Googled it and it seems to be a very common add on for these types of trailers.
1993 Sport Nautique
PCM 351w, no ProTec
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2021 at 9:57am
All my hitches are bolted on and unadjustable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: October-31-2021 at 10:18am
Doc you’ll have clearance from prop to driveway until one day you forget and Don’t   Leave it on
BTW. What have you done with Pete
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: November-01-2021 at 10:59am
Agree with 67, leave it on.  I'm guessing that guard has saved my prop a few dozen times at this point.  I love the idea of rollers on the guard, might look into that myself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DockDoc Quote  Post ReplyReply Direct Link To This Post Posted: November-01-2021 at 11:11am
yeah I agree too and will do so. Not worth trashing the bottom of the boat for this small problem. I'm really hoping a slightly lower hitch will fix the problem. Otherwise will look into rollers/casters, or even just ramps.
1993 Sport Nautique
PCM 351w, no ProTec
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: November-01-2021 at 2:00pm
I'm with HW, lower the hitch - it will be the next thing dragging. How about a lower ball mount or if yours can be turned over just do that.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DockDoc Quote  Post ReplyReply Direct Link To This Post Posted: November-01-2021 at 2:41pm
My fault, I'm confusing hitch and ball mount... I'm getting an adjustable ball mount.
1993 Sport Nautique
PCM 351w, no ProTec
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: November-01-2021 at 8:06pm
Sell house,   buy a more boat friendly residence Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote DockDoc Quote  Post ReplyReply Direct Link To This Post Posted: November-01-2021 at 8:08pm
Ugh literally just finished this brand new garage!!
Couldn’t convince the wife to move out to the lake so oh well
1993 Sport Nautique
PCM 351w, no ProTec
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2021 at 3:15pm
I fabricated a mount for the R/V type "butt dragger" steel roller wheel.  I have one wheel on each side of the prop cage.  The axle on the roller wheel has a grease zerk for lubrication.  The location of the roller wheel is about 3/4" below the prop cage.
I also have an adjustable ball mount so that I can drop the trailer tongue fairly low to get the a$$ end of the trailer (and prop cage) up with additional clearance if needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: November-02-2021 at 9:47pm
That looks bout perfect JQ.  Nice work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2021 at 12:11am
Thanks McD.  Those wheels are one of the best mods I've done on the trailer.  I have a fairly steep driveway, so the butt-dragger wheels are used many times during waterski season. I got real tired of the scraping and grinding of the prop cage and the marks left on the concrete.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2021 at 2:04am
Your welds look better than mine.   I am still working on that skill set.  I have a frame to modify, will give me lots of practice.
Where did you find the grazeable rollers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2021 at 10:45am
Where do you guys find adjustable hitches?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DockDoc Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2021 at 11:14am
1993 Sport Nautique
PCM 351w, no ProTec
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2021 at 11:21am
Linky no worky
Post Options Post Options   Thanks (0) Thanks(0)   Quote DockDoc Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2021 at 11:27am
1993 Sport Nautique
PCM 351w, no ProTec
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2021 at 11:31am
That’s not a hitch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DockDoc Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2021 at 11:31am
1993 Sport Nautique
PCM 351w, no ProTec
Post Options Post Options   Thanks (0) Thanks(0)   Quote DockDoc Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2021 at 11:35am
Yeah again because I'm an idiot and keep confusing "hitch" with "ball mount". My bad.
1993 Sport Nautique
PCM 351w, no ProTec
