New project 1965 mustang |
Page <1 45678 9> |
Bilkolayne ![]() Senior Member ![]() Joined: September-13-2016 Location: Sanford me Status: Offline Points: 135 |
No it is not possible for the cam to spend in the wrong rotation as long as there is gear to gear timing gears and not a chain. If the engine rotates clockwise and the distributor rotor button rotates counterclockwise... then the last person f***** up royally and has no idea what they were doing |
Riley ![]() Grand Poobah ![]() ![]() Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7952 |
I just spoke with him and he did replace the cam and chain with a RR cam and gear. I didn't remember that part. He reversed the rods, to minimize piston slap, although interestingly he is dismantling a PCM 454 RR engine right now and he says the rods were not reversed, so he says PCM converted the engine the "cheap way", by just changing the cam and gear. |
Pistons don't get installed backwards unless they have offset wrist pins... Which is not overly common. Never heard of installing a rod "backwards"... Can't think of how that would matter (I can't recall seeing an asymmetrical rod).
I highly doubt PCM was "converting" LH blocks to RH. The rear main seal needs to change and I just don't see them pulling the crank out to change the seal in every engine they got. I am sure they were ordering rotation specific longblocks directly from GM like every other marinizer. |
PCM or whoever reversed the rotation... I believe he said it was the wrist pins and the 454 out of the '86 is what he is dismantling right now. He says they're backwards. I'll be over there Thursday, maybe I can get a picture. I do remember him showing me why and how he was reversing the rods on the new SBC, but that was a few years ago.
I should clarify. The snout of the rev rotation cam is not the same as a standard rotation. It should not be possible to install a gear/gear timing set on a std rotation cam, or a chain on a rev rotation cam. So, whichever rotation causes the distributor to rotate clockwise, the engine will run that way- crank and cam will be in synch. |
What he said was the rods had not been reversed on the 454 PCM he has. I don't know if it's been monkeyed with or not. He wasn't blasphamyzing PCM. The only PCMs he's ever seen are the ones we've brought to him. Hollywood, you edited your post...
I am guessing he means that he'd spin the piston and rod combo around 180deg in order for the offset wrist pin (on the piston) to match the engine rotation. (Rods themselves should not care about rotation). Pistons that don't have offset wrist pins should be installed the normal way (valve reliefs will be in the right spot).
Like I said, PCM wasn't converting engine rotations, the long blocks were coming from the engine manufacturers. I don't think GM would have done that... I am guessing someone else had been inside that 454 and didn't put it back together quite right. Did it still have the original Pcm silver paint on it? |
Yes. Dave would know better than me if it had been apart prior to. I helped him take it apart, but that was 2 winters ago... Anyway,,,it sounds like there's no mixing up RR and LR engines so the OP should be fine. ![]() |
Thought about it more- rod orientation does matter, bearings are chamfered. Common sense says that the rods should not be spun around based on rotation, but I'll let someone more knowledgable field that question.
Discussions like these remind me of how much I miss @79Nautique, he always made that Rabbit hole very interesting!
I was thinking of 79 as well. Dave and I are going over to Jim's Thursday to borrow some equipment. Perhaps Jim can explain it to Dave and Dave can translate it to Tim... I just know he reversed all the pistons and rods when he switched rotations... If Jim knows what he's talking about, I suppose it is even more critical on a RR race engine... |
Don't know about the "More Knowledgeable" but the locks on the bearing have to face outboard. That puts the bearing in the correct location for the radius of the crank throw. Fords are notorious for having .060 offset wrist pins. On flat tops there are 4 valve reliefs. Just had that conversation with Sealed Power tech guy couple weeks ago. Ford marine engines (with offset pins) have the piston notch to the rear and bearing locks still outboard Did I just confuse things more? ![]() |
1978 Mustang (modified) |
OK so off topic of what you guys are talking about. I just watched the engine when it rotated by the starter and the flywheel spins clockwise and so dose the rotor butten and the fireing order of the valves are righthand also so there for it is all correct a right hand engine. Dose that ancers your questions.
No I think you confirmed what I was thinking... Pistons can be rotated 180 for rotation but rods should not be.
We will see what's up when I get it fired up I'm not pulling pistons or rods just to check. So far everything checks out fine.
The guy I bought it from told me that the engine ran and thay where trying to make carb adjustments when it went up in flames. I don't see that to be a reason to check the pistons for proper placement
Jonathan, no one is suggesting you do that. You've confirmed the rotation and that's good enough.
Should be good to go. As long as the plug wires are in the proper order, you'll be fine. You asked a question about the intake previously too. As far as I know, all SBC's 262 through 400 can share the same intake. At least up t0 '86 model year. In '87 they went to a different bolt pattern for the center line valve covers. Vortec heads are a different story but yours definitely aren't Vortec's nor the post '87 heads. As long as the intake you want to install has the '86 and older bolt pattern, it should work.. |
Eddie |
OK so for ******* and giggles I got a fire extinguisher some wire and some ether.... i installed the new distributor and quickly wired up the power supply to it and gave a shot of ether down the old carb and she fired right up. Just for a sec tho..... I just wanted to here it fire
Tim's "no" was for Duane I think, not your post in between them.
Even if it was just for a sec I'm so glad I got to here it fire up today.... I got this wireing down pat now and just need to pickup more wire and connectors I will do that tomorrow sometime.
wtf it's only 3:30
Lmao but I only ran some wire to a battery really rigid just to fire it up. |
While you'r at it, throw the starting fluid as far as you can throw it!!!!!!!!!!! Might be OK for diesels but NOT for gas engines.
I know this that's why I put a small shot oil in each cylinder and cranked it over before I did that..... I am a mechanic don't forget that. |
Boy I love when you guys talk like this......don't understand it but love it, john |
I did not get anything done today as I was stuck at work all day so I brought one of the burnt up valve covers to work and was able to clean it up its back to normal now nice and shiny. Nothing a little never dull and a wire brush could not handle. My carb spacer should be inn tomorrow some time. Hope to get the carb all hooked up and some wireing done.
Can someone tell me what the two big wires on the right side of the transmission are for?
big?
neutral safety switch? interrupter in the starting circuit so you can't fire it up in gear. |
Page <1 45678 9> |
