Boat won't start..possible keypad issues |
kconklin ![]() Newbie ![]() Joined: June-24-2013 Location: Texas Status: Offline Points: 7 |
![]() ![]() ![]() ![]() ![]() Posted: June-24-2013 at 1:09pm |
I have a 2000 pro air nautique that won't start. This boat has a keypad that requires a code to start. I went to put it in the lake this weekend and it was completely dead..thought it was a battery issue, so bought a battery and still nothing. The green light blinks when entering the code but nothing happens when i press start. the radio doesn't come on or anything..the horn honks and the bilge seems to work but but not getting any power to the ignition. I am a female so not too familiar with boats, what to check or where to even take it for repair. Any feedback would be appreciated. Thanks.
KKC
bkhallpass ![]() Grand Poobah ![]() ![]() Joined: March-29-2005 Location: United States Status: Offline Points: 4723 |
Make sure the throttle is in Neutral. Also, check that the safety lanyard is properly attached. Those are the two most likely culprits.
BKH |
Livin' the Dream
mdvalant ![]() Grand Poobah ![]() ![]() Joined: May-06-2009 Location: Bellevue, IA Status: Offline Points: 2059 |
Hey there...had a similar problem on our 2000 Sport Nautique. Sometimes it's the left keypad. Sometimes its' the right keypad. Sometimes it's the PME (Main breaker box under the steering wheel)
Ours was the PME. Larry Shay at FL Nautique can test your keypads for you if you send them to him. We sent out left keypad thinking/hoping it'd be that but he replied and sent it back indicating it was perfectly fine. Replaced our PME and BAM...back on the water. FYI: Our blower would work..but as I recall nothing else. (Horn got wet so the actual horn is toast I think, otherwise I think it woulda worked) Hope this helps. Email me if you have any other questions! |
what do you mean by left and right keypad? I have one keypad to the left of the steering wheel that has numbers and start/stop buttons. what other keypads are there?
KKC
also throttle is in neutral and lanyard is properly attached..
KKC
![]() Left would be blower/keycode/start stop Right is bilge/lights/acc/shower/etc etc Make sense? Sorry if I was vague! |
how do i test the PME and where do i get a new one if that's the problem? Should a local marine shop be able to help me or am I going to have to take it to a nautique dealer?
KKC
That's a good question... We ordered ours from whitelake (Nautiqueparts) marine I believe. Very easy to install. I would recommend contacting them and asking if they can check your keypad. You have an option to buy the keypad...if it doesn't fix it send it back and buy the PME instead. Nautique Parts Need Help? Call us: 910.247.6201 orders@nautiqueparts.com http://www.nautiqueparts.com/ |
oh i see!! so if the right keypad is not working then it won't start either? do you have contact info for the guy that tested your keypads?
KKC
PM'd you my guys' contact info.
thanks so much! I'll definitely give this place a call!
KKC
brockcan2002 ![]() Newbie ![]() Joined: June-02-2011 Status: Offline Points: 10 |
I am having similar issue with my 2000 air nautique except I get no lights when entering the code. Clock is not working and battery is brand new. Was thinking it is the ignition fuse but no idea how to check it
I'm not sure on the ignition fuse., I have an inline fuse off the positive terminal of my battery up under the front nose cushion in our 2000 sport. I've blown that a few times, not sure how. You could be having keypad issues, or PME (large black box that holds the computer up under the dash) issues. We've had to replace both our start keypad, and our PME over the last few years. |
Thank you I will check that
frozenskier ![]() Groupie ![]() Joined: September-19-2011 Location: northern ny Status: Offline Points: 102 |
FWIW check the battery terminal connections. I had trouble this spring getting my 05 196 started. Same symptoms, bilge pump ran, horn worked etc but just clicked when I hit the start button. Turns out the Neg battery cable terminal needed to be replaced, also check the positive one to be sure it is clean and securely connected.
I forgot to mention the battery terminal issues. We had to replace our negative wire terminal connector as well.
Tim D ![]() Grand Poobah ![]() Joined: August-23-2004 Location: United States Status: Offline Points: 2637 |
You mentioned the battery is new. If the positive and negative cables touched each other during the battery change, the keypad is toast.
Tim D
