1990 Platform Brackets |
Author | |||
barnum910 ![]() Newbie ![]() Joined: May-22-2011 Location: Ballston Lk NY Status: Offline Points: 6 |
![]() ![]() ![]() ![]() ![]() Posted: May-22-2011 at 4:58pm |
Is there anything special about brackets for 1990 ski nautique? I see in ccf store there are brackets for up to 1989 then after that they are different?
I bought a used 1990 ski nautique that had platform and brackets stolen. The platform in ccf seems reasonably priced but I would still need to find brackets. Would the 1989 pair work? |
kapla ![]() Grand Poobah ![]() ![]() Joined: March-27-2008 Location: BA, Argentina Status: Offline Points: 6148 |
1990 + brackets are removable...
The platform slides over a base that stay in the hull.. thats the hull bracket. the plastform side slides over that part |
mdvalant ![]() Grand Poobah ![]() ![]() Joined: May-06-2009 Location: Bellevue, IA Status: Offline Points: 2059 |
To answer the question, NO...the 89 brackets would not work. Unless you wanted to do some custom work :)
I think in his case the ones that are for sale in the CCF store for the 81 boats might work...
Better do an inquiry to the seller and let him comfirm if will or not work...Is the hull part (as the one pictured in the photo) still in the transom? |
That is highly doubtful. The rise and swing angles of the brackets are usually pretty different from model to model. I would not think that a 80 SN and a 90 SN would match. Get the angle just slightly off (just by a degree or 2) and the brackets will either not match your platform (they'll be toed in or out too much) or the platform itself will be angled incorrectly in the water. I would call Alloy Marine and speak with them directly. |
These are the same type of brackets that are on my hull also.
I guess ill check some local marinas that sell correct craft. Or other places you can think of? |
75 Tique ![]() Grand Poobah ![]() ![]() Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6114 |
Don't think a dealer will be much help. Do like TRBenj said and call Alloy Marine 800-892-1770. Just because the bracket on the boat looks like yours does not mean the bracket portion screwed to the platform is the same. As Tim said the vertical and horizontal angles of the bracket are different for different hulls. Alloy will probably have the specs for the bracket for your hull. If not, they will send you a form showing how to measure to fit your boat, that you fill out and send back. Also Billy/Karen at MyCorrectCraftParts.com (advertiser on this site...phone is better) can help you, I believe they are still a vendor for Alloy Marine.
I ended up ordering brackets from local dealer and platform from ccf. Should be all set. Thanks for the help.
Where can you get the little stickers at rear sides of hull. one is a triangle and others are rectangles, etc? |
Morfoot ![]() Grand Poobah ![]() ![]() Joined: February-06-2004 Location: South Lanier Status: Offline Points: 5313 |
Marty Mabe is the decal dude around here for the larger type decals and chrome ones for the trailer. Pauly Banana has allot of the smaller warning type decals, special decals and the ski nautique decal on the trailers as well. Check with both those guys and they'll hook you up.
KRoundy ![]() Platinum Member ![]() ![]() Joined: August-23-2010 Location: Lake Stevens Status: Offline Points: 1702 |
Will need to do this eventually on my boat. Thanks for blazing the trail for me.
Marty will definitely hook you up with the decals. |
Err, hopefully your reading comprehension skills are a little better! ![]()
In case it wasnt perfectly clear, Alloy Marine is the manufacturer of the brackets. They will have a full list of all the boats with the correct rise and swing angles. By buying direct you'll save a bunch of money as well. |
MartyMabe ![]() Grand Poobah ![]() ![]() Joined: February-21-2006 Location: High Point,NC Status: Offline Points: 3974 |
Mike Barnum, I can't reply to you if you don't get me an e-mail. You don't show one in your profile.
The Larger side Hull decals-- White Lake Marine or TimD can help you out. The smaller manufacture decals and the Triangle decal I can help you with. Shoot me an e-mail mtmabe@northstate.net Thanks, Marty Mabe |
