Knocking comming from Drive area |
80nauts
Groupie Joined: March-19-2005 Location: United States Status: Offline Points: 93 |
Posted: August-15-2005 at 8:00pm |
When I first put my boat in the water and idle in gear then I hear a slow knocking sound till I take off. When the boat warms up the noise is gone. Any ideas on how to find out what is going on?
The transmission seems to be running smooth and the sound seems to be inbetween the trans and prop area. The prop is tight. Thanks for any Ideas...This website is great. |
ultrahots
Gold Member Joined: September-08-2004 Location: United States Status: Offline Points: 618 |
Coupler between motor and trans ? I have seen a few make noises in the past.When you load the boat the noise goes away.
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3338 |
And most velvet drives knock if the idle is too low or eratic, it doesn't take much.
mackwrench
Senior Member Joined: February-25-2005 Location: Gone Status: Offline Points: 190 |
Sounds like the engine/trans coupler is bad.
This subjuect has come up a few times here and thats the common cause... |
NO LONGER A MEMBER
guest
Guest |
damper plate? is that the coupler?
mackwrench
correct
NO LONGER A MEMBER
80nauts
I replaced one of those on a friends boat. I hope it doesn't mean it will fail. I just don't want to be stuck on the lake somewhere.
88skisupreme
Guest |
is there an old thread or online guide about changin the damper plate? I think my boat needs one two. look like a big job to seperate the tranny.
80nauts
I upped the idle a little bit and the knocking is all but gone. I guess it is just noisy at a low idle. I wonder if it has something to do with a relationship between centrifical force or whatever and engaging completely into drive.
tommer12
Senior Member Joined: February-05-2004 Location: United States Status: Offline Points: 366 |
If it's a velvet drive, it's probably the damper plate between the tranny and the engine. There are 4-5 springs around the plate that rust out over time. I had mine replaced on my old 84' for about $500 a dealer. PCM makes a replacement plate for about $150, then the rest is labor. Pull the tranny out, pop the old plate, put the new plate on, reinstall tranny.
there is another thread here on it. cheers tc |
Bob's2001
Senior Member Joined: March-28-2005 Location: Lake Jackson TX Status: Offline Points: 241 |
Mine was knocking like that just before it quit. It felt a little stiff going into gear that day and just quit going while I was up on ski. At least we all got a turn before it quit. I'm pulling the trans to see what's broke.
Bob Ed
83 2001 |
