85 SKI NAUTIQUE BREAKER/SWITCHES |
HOLESHOT ![]() Groupie ![]() Joined: July-08-2005 Location: United States Status: Offline Points: 47 |
![]() ![]() ![]() ![]() ![]() Posted: July-16-2005 at 10:22pm |
I NEED NEW BREAKER SWITCHES FOR A 85 2001 SN
YOU NO THE ONES THAT NO ONE CAN FIND PLEASE HELP |
IF IT HAS A SPARKPLUG I CAN FIX IT
Keith ![]() Admin Group ![]() ![]() Owner / Operator of CorrectCraftFan.com Joined: October-20-2003 Location: Pepperell, MA Status: Offline Points: 1917 |
You can get them from Discout Inboard Marine. Be sure to enter the promotion code CCFAN and get 10% off your order.
-Keith |
i need the switches on the dash that are switches and breakers bcause there are no fuse holders on the dash like on me 82 should i just convert the 86
I believe your '85 is just like the '86. There are a series of ETA push button switch/breakers. The replacements are available through the link above.
-Keith |
those look like plain ol breakers to me this natique has what seems to me to be both switch and circut breaker in one if you whant to turn it off you can there white w/ black tip . help .
the dash also has a red lite next to the switch no fuse no seperate swith its all in one |
backcrkr ![]() Newbie ![]() Joined: April-20-2005 Location: United States Status: Offline Points: 23 |
Thoese look like the ones on my boat. I have an 86, but I replaced the switches with standard toggle switches. be carefull putting anything aftermarket, its a very tight fit
Holeshot,
Scroll down on that page and you'll see exactly what you need. I just ordered 6 of them for my boat. The ETA switches are push button on/off switchs but also are breakers. They come in various amp ratings (2.5,6,10,etc.) Here is a direct link to the 6 amp breaker/switch. Backcrkr, Be careful replacing these with regular toggle switches. The breaker/switches pop (or break) when the amps exceed the rated level. Unless you also install in-line fuses, you could have a potential fire hazard. -Keith |
keith thanks problem solved got some onthe way
