Voltage drops as RPMs increase
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=51900
Printed Date: May-03-2025 at 3:30am
Topic: Voltage drops as RPMs increase
Posted By: uncle-buck
Subject: Voltage drops as RPMs increase
Date Posted: April-02-2025 at 11:08am
Took my boat out on Sunday, for the first time this season. Noticed that voltage shown on the dashboard volt meter decreases as engine RPMs increase. Haven't seen that before.
Have done the following troubleshooting steps so far:
Checked the alternator belt: it's tight
Checked voltage output at orange alternator wire: 13.9V to 14.0V
Checked voltage at battery with engine running: 13.9V to 14.0V
Checked and cleaned ground wire connection on the alternator.
Cleaned and cleaned ground wire connection on the top of intake manifold.
What other troubleshooting steps I should take?
Thanks
1990 Ski Nautique (original owner)
PCM 351W with D.U.I.
Posted By: GottaSki
Date Posted: April-02-2025 at 12:35pm
I suspect you could  be seeing unloading of the ignition wire (purple) as rpms increase.
yes, more sparks at higher rpm,  but maybe that also means less time with the coil drawing current energizing the field, because it sparks when the field collapses, not energizing
when your purple wire gets ohmic due to age, the quick disconnects, connections, keyswitch, breaker/fuse, etc, build series resistances that can add up, and  odd things happen.
Lots of components are pulling current through that one, undersized wire. Sometimes If you look how the factory daisychaned off the buss bar to eventually get the the switch and beyond, usually with undersized wire, you may be aghast
River Rat to Mole
Date Posted: April-02-2025 at 12:44pm
So, is a possible solution the replacement of that purple wire with a heavier one?
Posted By: GottaSki
Date Posted: April-02-2025 at 1:13pm
somewhat, never hurts. but every connection prior is even more suspect as well . to affect your gauge, extra resistance has to also exist prior to where the voltmeter and purple to engine diverge
River Rat to Mole
Posted By: KENO
Date Posted: April-02-2025 at 6:54pm
I'd probably take your meter and hook it to the back of the dash voltmeter and see what it reads...
when the engine is idling_________________
when it's at higher speed_______________
compare those numbers to the dash gauge
when the engine is idling....................
when it's at higher speed...................
You mention 13-9 to 14 volts at the alternator and at the battery, is that both idling and at speed ?
There could be more questions, but if you answer these it's at least a start
Meanwhile I have to  try to figure out this ohmic thing. mentioned earlier It must mean that a perfectly good wire and connections is called something else like non ohmic or something if it turns ohmic with age Wink
Date Posted: April-02-2025 at 11:27pm
Will check soon and reply.
Thx!
Date Posted: April-03-2025 at 11:42am
Ken, I *think* the mystery has been solved.
Am getting good voltage numbers at the back of the voltmeter, alternator, and on the battery at both idle and 2,000 rpms.
But the voltmeter failed during the diagnostic process.
Have ordered a replacement and will report back after installation.
Thanks
Date Posted: April-04-2025 at 12:21pm
Installed a new Faria Beede voltmeter. It reads about one-quarter volt lower than my multimeter, which is close enough.
Am still getting some voltage drop at higher RPMs, but much less than previously. I assume there's a fair amount of resistance in the daisy chain of 35 yr. old wires in the dash pod.
Am going to enjoy the boat for now, and consider rewiring the dash pod next winter.
Thanks for your helpful replies.
