prop size
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=51312
Printed Date: May-04-2025 at 1:55pm
Topic: prop size
Posted By: tarpon32
Subject: prop size
Date Posted: August-16-2023 at 12:49pm
 Information on a new prop for 1990 Nautique, 351 Ford, take long boat trips , looking for prop at 2000-2100 rpm that will give max speed. Now 2100 rpm at 25 mph 3 blade.
Randy
Posted By: Tomrupp
Date Posted: August-16-2023 at 1:19pm
25 at 2100 is pretty fast. I’m closer to 22 with 4 blade and same hull as you.
Tom
94 Ski Nautique Open Bow 351 with Carb
95 Double Decker Aqua Patio with 50hp Honda (3 carbs).
Posted By: Jonny Quest
Date Posted: August-17-2023 at 12:08am
Reach out to Tim Benjamin on this site: TRBenj
Great info on props.
Posted By: KENO
Date Posted: August-17-2023 at 7:18am
He'd probably wonder what brand and size is on it right now to give those numbers.
He'd probably also wonder if the tach is accurate and the speed is GPS verified, since like Tom said, 25 mph at 2100 rpm is pretty fast now with whatever is on it Wink
Posted By: GottaSki
Date Posted: August-17-2023 at 8:28am
I don;t think youre going to save what you think you are going to save.
if you get the rpms lower, the manifold vacuum will be lower(numerically) because one still has to burn x gas to do x work
River Rat to Mole
