Want to upgrade 351w alternator |
Author | |||
Hysteria ![]() Groupie ![]() Joined: May-31-2020 Location: Indiana Status: Offline Points: 70 |
![]() ![]() ![]() ![]() ![]() Posted: February-09-2021 at 10:39am |
Anyone have a suggestion for a marine alternator that will bolt up to my '76 Nautique with a 351 windsor? I'm not terribly familiar with these motors and am guessing some people on here have already been down this road before me. I'm not too concerned about the wiring configuration, just looking for a recommendation that bolts up without too many fitment issues and is decent quality.
Thanks! |
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 11269 |
Is this a PCM 351? They'll all bolt up with very minor modification. The AMN 0002 will need a jumper wire between the "s" terminal and the output terminal and then it can be wired like in the mid 80's diagram below. They'll all do away with your external voltage regulator on your 76 ![]() The picture below shows where the jumper would go on the Mando style alternator. It's the strap between the "s" and output terminal with the black sleeve over it, but a 10 gauge wire works just fine. ![]() |
Thank you for the information! Yes, it's a PCM 351 in the boat. I'll get on DB electrical tonight and see if I can find a Delco that will fit, I'm just not sure about which model will bolt up to my motor. This is my first boat so I'm not familiar with any differences I would need to look out for with it being outfitted by PCM vs the normal 351 automotive application. I'm assuming the reverse rotation won't matter since it's rectifying AC current anyway, but correct me if I'm wrong on that.
Link to a 1 wire marine Delco style below Link to a 3 wire marine Delco style below Reverse rotation doesn't matter electrically and the cooling fan flow is plenty in either direction Remember, more amp capability like the 100 amp plus ones that they have for example, (that I didn't link), means heavier wiring, bigger main breaker if your 76 has a breaker ![]() |
Thank you for the links, that takes the guesswork out of it on my end. I'll be rewiring the whole boat so everything will be sized appropriately for its load, but that's a great point to make
Nautiquehunter ![]() Platinum Member ![]() ![]() Joined: December-31-2008 Location: Lake Lanier GA Status: Offline Points: 1010 |
I just put a DB 1 wire on my 67 Mustang 351w .
How do you like it? I went ahead and ordered a 3 wire last night from the link KENO provided
fanofccfan ![]() Platinum Member ![]() ![]() Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1801 |
I have had the one wire for several years. works great and less confusion for my sometimes confused mind!
Hysteria, here's a post from a thread a little while back talking about 1 wire and 3 wire alternators. Either one will work good for you ![]()
Another highly informative post. I ordered the 3 wire to avoid the issues you outlined with exciting the field, and I also like the idea of having control over the voltage reference that the alternator uses.
