Glenwood header?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=9743
Printed Date: May-14-2024 at 3:57am
Topic: Glenwood header?
Posted By: CJ Bech
Subject: Glenwood header?
Date Posted: February-29-2008 at 2:11am
I was wondering about putting some Glenwood headers on my chevy ,the old cast manifolds are about dead,are these any good? i have herd they are the best,any other wet headers out there?,thanks
Date Posted: February-29-2008 at 12:49pm
Lots of options for Chevies. What are your goals, and what do you want to spend?
Posted By: CJ Bech
Date Posted: March-01-2008 at 12:14pm
I know where a pair of GW headers for sale,w/risers they want $400,looked on the GW site and headers w/riser are about $1200,is there alot of gain in useing them,seems like it would breath better,they seem like a good deal?,any feedback would be great,also my 69 SN has a 225 chrysler,and would like to put some wet headers on it, but can't find any,thanks
Posted By: Riley
Date Posted: March-01-2008 at 12:21pm
Edie Marine make them also, price is up there though.
Date Posted: March-01-2008 at 12:44pm
http://barrmarine.net/wordpress/chrysler-v8-273-318-340-and-360-cid-2/ - barr marine manifolds for the 318, 225 HP
CJ, Unless you are planning on other engine mods,I don't feel the gains with a header type manifold would be worth it. The cast iron is certainly a less expensive way to go.
Of coarse, the $400 doesn't sound bad IF they are in good condition. Watch out on the aluminum!!
Posted By: eric lavine
Date Posted: March-01-2008 at 12:52pm
im with you Pete, spend the money on some cast, there is no revelation when you slap aluminum headers on these engines, it probably will make the engine a little more crispy but for the dollar there are better ways top gain HP, a simple intake change from stock will gain you as much HP, It depends what your intentions are and how deep your pockets are.
Date Posted: March-01-2008 at 1:05pm
They do look very pretty though!!!
Date Posted: March-01-2008 at 1:09pm
not with the cover closed,
Posted By: Riley
Date Posted: March-01-2008 at 1:11pm
When Indmar added the EXTs to their existing line up, they claimed an increase in hp of 5%.
Posted By: boat dr
Date Posted: March-01-2008 at 1:12pm
CJ, save your pennys , the Hi Teks will give you more bang but will cost more buck.
The Stainless Steel construction will mean you only but one set.There is a hp increase with this bolt on, but cost per HP is large.
But the polished ones sure do look good............Boat dr
I do not regret my purchase...........
------------- boat dr
Date Posted: March-01-2008 at 1:15pm
1200.00 for a 5%increase?
Posted By: Riley
Date Posted: March-01-2008 at 1:22pm
Seeing that would only be 5hp for my Interceptor, that is a little pricey for me.
Date Posted: March-01-2008 at 1:28pm
BD combs his hair in that mirror finish,
Posted By: boat dr
Date Posted: March-01-2008 at 2:53pm
eric.......WRONG...... i don't have any hair.
I wish I could have bought them for 1200.00.lOOKING BACK IT WAS A GOOD PURCHASE, SAVED a lot of weight......
Date Posted: March-01-2008 at 3:05pm
Eric, The Doc is being honest! I've met him in person and if I had to describe the style of what hair he does have, I'd have to say it is a RN crew cut!!!
Posted By: Riley
Date Posted: March-01-2008 at 3:12pm
Eric, if I hit the lottery tonight, and decide to spend about $10k getting my Interceptor up to 150hp, is the Dearbo going to handle it?
Date Posted: March-01-2008 at 3:54pm
BD i said hair which means singular,
Riley...dont push it, I dont know much history on these because of the rarity of them, if it was a Borg i could build you one to take around 800 ponies
Posted By: Riley
Date Posted: March-01-2008 at 4:15pm
Well then I guess if I hit it big I will be converting to a borg and maybe one of those high reving 283's.
If I was going to ever convert to a V8, I'd have to cut new exhaust holes in the transom, which wouldn't be a problem as there are already reinforced spots on the transome, but how difficult would it be to fill the existing exhaust hole and gel coat it over?
Date Posted: March-01-2008 at 4:18pm
pretty easy, plug with wood, glass the backside, duraglass the front and finish then paint
Posted By: Riley
Date Posted: March-01-2008 at 4:33pm
Something to think about for the long term. The hull and gel on the boat are really nice. Hopefully, my current engine and tranny will work fine, but if I ever got to the point where I had to dump a significant amount of money into them, I'd rather convert to a V8 and velvet drive. But I hope I don't get to that point until everything else is done.
Date Posted: March-01-2008 at 5:29pm
Bruce, Go and get the parts for the HP. Stroke/bore it to the next size which was 200 C.I. and push it to the 170 to 180 HP range. First I trust Eric and second it wasn't until they put the Dearbo on the 312 with 215 HP that they started having issues.
If you are serious about a V8, I would keep your eyes open for a nice vintage 289 Interceptor with a Velvet. It should fit under you dog house and they aren't a problem to rebuild. You of coarse would then need to join the Mustang/American skier group of speed freaks!! A stroked small block Ford with 289 tags on it!
Posted By: Riley
Date Posted: March-01-2008 at 5:38pm
Eric, Pete says we're ok.
Pete, I'll be happy with the current set up if it runs well without me sinking a boat load of money into it. I hear a reman. 200 short block is the least expensive way to go for upgrading a 170.
If I got to throw a lot of money at something, I'd rather do it at a set up I like. Hopefully, it won't come to that.
Date Posted: March-01-2008 at 9:10pm
eric lavine wrote:
BD combs his hair in that mirror finish, |
Speaking of hair, where has Jbear been??
Posted By: CJ Bech
Date Posted: March-03-2008 at 11:16am
Thanks for the info,i will buy them if they test ok,what intake would work good with these?
Posted By: jbear
Date Posted: March-04-2008 at 3:18am
Been up in Ohio Pete....thanks for missing me.
Was jones'in to get back on here with you guys.
john
Posted By: adamt
Date Posted: March-04-2008 at 3:39am
Welcome home jbear, late night?
------------- -Adam
1973 Skier
Posted By: jbear
Date Posted: March-04-2008 at 3:58am
Yeah...just got on an hour ago. Gotta head for the shower or I won't be able to get up for work tomorrow. Still got my phone number? I lost yours. Wanna be able to stay in touch. You're up pretty late too.
john
Posted By: adamt
Date Posted: March-04-2008 at 4:05am
I was just looking at the info about the GL Reunion, it would be nice, at least I can dream! I got your e-mail address, I'll send you our phone #s. Talk to you later, have a good night,
Adam
------------- -Adam
1973 Skier
Date Posted: March-04-2008 at 10:02am
John,you were in Ohio? thanks for missing me...lol eric
Holleywood was in Ohio and he came to see me
Posted By: jbear
Date Posted: March-04-2008 at 11:53pm
eric lavine wrote:
Holleywood was in Ohio and he came to see me |
A very nice young man named "Hollywood" with a very nice looking friend by the name of Carolyn was just here in Florida weekend before last to spend some time with us. Must be some imposter that came to see you.
Actually I would have stopped but I did not have my shots or a brunstucky passport. Definatly could not chance being stopped without proper papers...did not want to end up on the chain-gang. A Strongsville native only wants to visit brunstucky (briefly) not have to stay for any lenght of time.
BTW: Nice job on MM's tranny. Ran very well and fast on the St John's river. Did ya see the pics?
john
Posted By: jbear
Date Posted: March-04-2008 at 11:54pm
john
Posted By: Gary S
Date Posted: March-05-2008 at 1:25am
Been wondering where you've been.Did you go up to see how good you got it in Fla? Nice river pic's, is that fresh water all the way? Your going to have to save your money to buy a laptop next time so you don't have withdrawals
Posted By: Hollywood
Actually John, I stopped in Eric's shop on my way out of Cleveland, the same day we left your house. I'm gonna have to go buy some notebook paper to write you and Patti a thank you.
Posted By: jbear
Date Posted: March-05-2008 at 1:37am
Gary: Just sent ya a message on another thread. A laptop is in the near future I think. Of course after I took over this computer from Patti after I found C/CFAN...I might not get on the new one.
HW: Not necessary. I have the suits packed up. You want me to drop them at the shipping place?
Hope you and Carolyn had as good a time as me and Patti did. BTW; Patti took her sister back to the go-carts this weekend while I was in Ohio...so she musta had fun too.
john
Posted By: CJ Bech
Date Posted: March-05-2008 at 2:49am
Hey Hijack,hows it going,oh thats cool ,i'll try you on another post,just wanted to say hi,see you soon.................
Posted By: jbear
Date Posted: March-05-2008 at 2:52am
Sorry about the thread jack CJ.
john
Date Posted: March-05-2008 at 9:34am
John, I understand you gotta keep a low profile, one of your ex's might of spotted you and hit you up for child support, i seen pictures of everything but the tranny..all nice shots
Posted By: CJ Bech
Date Posted: March-09-2008 at 4:37pm
well thanks to all that helped me with this post anyway i bought them and they are very cool,CJB
