V drive problem on super air nautique
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=8669
Printed Date: May-06-2024 at 11:17pm
Topic: V drive problem on super air nautique
Posted By: Cheaterpete
Subject: V drive problem on super air nautique
Date Posted: October-09-2007 at 3:05pm
Hi all
My friend and I was on the lake last sunday, after few rides, the Vdrive start to make a CLAC CLAC... so we stop, and dismount it, we found a pinion wwith 2 teeth broken...
do you have any idea where I can order these pinion?
thanks for your help
Pete
------------- Actual boat SANTE 210 from 2014
Posted By: eric lavine
Date Posted: October-09-2007 at 3:55pm
we do need a trans model and serial number to guide you in the right direction, as for getting the parts that will not be a problem, What do you suspect caused the problem so this wont happen again?
the trans is probably a Walters rv20 but we need to be exact, it will either have a Borg Warner or a PCM40 in front of the Walters....again we need the information off of the transmissions
Eric
Date Posted: October-09-2007 at 8:01pm
Walters rv20 , that what is on the v drive, the boat sank last year and I think water was still on the v drive, the oil was looking bad, I think the cause of the problem start here....
