Carter AFB Carb Experts?
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=42411
Printed Date: April-28-2024 at 4:07am
Topic: Carter AFB Carb Experts?
Posted By: Frankenotter
Subject: Carter AFB Carb Experts?
Date Posted: February-15-2018 at 5:35pm
I'm just following up with a fork in the road I encountered while overhauling the Carter Aluminum Four Barrel.
The floats that came out of the carb were caked with 20+ year old tar gas and were slightly caved in from pressure over time.
I bought new Carter floats that seemed to match up from the tiny internet pics available. When I got them side by side with the originals, you can see the difference. Not only is the arm angle different, but the physical size of the float is bigger in the new parts.
So before I get out the soldier tools and a bible, does anyone know a source for old timey Carter parts?
Chris
------------- 1999 Ski Nautique 196
Date Posted: February-15-2018 at 5:42pm
You may need to hit the gym if you don’t think you can bend that bracket by hand. That’s a typical way to adjust float height (at least on a holley). What’s the concern with the size?
Posted By: Fl Inboards
Date Posted: February-15-2018 at 5:50pm
Are there any Carter experts here? My only experience with them is removing them and throwing them in the scrap bin and installing a Holley! Looks to me like the float bracket needs bent. A 10 pound sledge should do it! wait! overkill try a pair of needle nose pliers..
------------- Hobby Boats can be expensive when the hobbyist is limited on their own skill and expertise.
Date Posted: February-15-2018 at 6:05pm
I wish that was the only concern, but bending it simply wont work. The attachment point of the arm to the float is different and it will effect the contact angle of the needle.
Posted By: chau8238
Date Posted: February-15-2018 at 6:07pm
You just need to bend the tabs so that they are properly adjusted per the manual. The size difference shouldn't be an issue, as long as the fit the area and don't hang up on the sides of the fuel bowels.
There's plenty of videos and forums with how-tos if you need help. It's the same as an edelbrock carb.
Date Posted: February-15-2018 at 6:39pm
This may help to show the problem. New Float
Old Float
There is well over 1/10" difference in the anchor point of the float arm. I think simply bending the are wont change the way the needle contacts the float. Not to mention the difference in the shape of the new floats is much broader on the bottom side.
My experience with the holly floats is that the difference of a few degrees makes a huge difference in weather the needle seats properly or not.
Posted By: MrMcD
Date Posted: February-15-2018 at 6:51pm
Bend it. I have had very good success running the Carter Carbs. Very reliable and not hard to tune without tearing the carb apart. I have also run my share of Holley Carbs and know about power valve issues etc. The Holley works very well and makes a couple more HP than a Carter but the Carter is usually trouble free which is worth something. BTW, Carter, Edelbrock and Webber Marine all come out of the same molds but Carter had them first.
Posted By: SNobsessed
Date Posted: February-15-2018 at 6:55pm
Well Chris, if it was me I'd bend a z into the arm, or solder a washer to get the offset you need.
Study how the old float sits on the closed needle & try to match that.
What do you have to lose but some time?
Date Posted: February-15-2018 at 7:03pm
I agree Chris.
I was hoping someone here had some insight to the original floats instead of modifying these. I was actually going to put the original on a mill with a DRO and get an exact measurement for the displacement. Then I can just re-solder the arm to the correct height.
Posted By: KENO
Date Posted: February-15-2018 at 7:29pm
Far from an expert, but I can tell you that your original floats are for a Carter AFB carburetor and the ones you bought are probably for a Carter AVS carburetor.
They were sized/shaped a little differently and the pivot point was different too. Sounds just like your problem.
You could do some bending and whatever else or you could order the right floats and be all set.
Posted By: KENO
Date Posted: February-15-2018 at 7:37pm
Here's a website with floats for both. The AFB cost a lot less
https://quadrajetparts.com/afb-avs-floats-c-299_130_140.html" rel="nofollow - floats
Date Posted: February-15-2018 at 7:49pm
YES!!!!!
Keno to the rescue! Bada$$!
Thanks Ken!
Posted By: KENO
Date Posted: February-15-2018 at 8:14pm
Glad to help
And don't listen to anyone who thinks they're worthy of the scrap pile
They're a whole lot different than a Holley but if you take the time to get to know them they're easy to tune and maintain whether they're named Carter, Edelbrock or Weber.
Posted By: Riley
Date Posted: February-15-2018 at 8:18pm
I don't understand the dislike for them among CCF.
Date Posted: February-15-2018 at 9:05pm
Riley wrote:
I don't understand the dislike for them among CCF. | I have a feeling it's just because over the years we've ended up with more owners with Fords and the Mopars have dwindled.
Posted By: Gary S
Date Posted: February-15-2018 at 9:42pm
I don't think so Pete,it isn't just boats. Back in the stone age of the early 70 everyone was pulling their carbs off and putting Holley's on. They even came standard on AAR Cudas and other muscle cars of the day. Carters just were not considered hi performance.
Date Posted: February-15-2018 at 9:46pm
They certainly do look cool on the classics that came with them originally... and they seem to work just fine. I don’t understand them like I do Holley’s but my perception matches Gary’s description- they’re not as well suited to a high performance application.
Date Posted: February-15-2018 at 9:56pm
TRBenj wrote:
They certainly do look cool on the classics that came with them originally... and they seem to work just fine. I don’t understand them like I do Holley’s but my perception matches Gary’s description- they’re not as well suited to a high performance application. | I never considered the basic 318 that's in many of our classic CC's to be a high performance engine.
Posted By: chau8238
Date Posted: February-16-2018 at 12:56am
8122pbrainard wrote:
Riley wrote:
I don't understand the dislike for them among CCF. | I have a feeling it's just because over the years we've ended up with more owners with Fords and the Mopars have dwindled. |
I will admit edelbrocks aren't suited for performance, but our boats aren't performance boats either. They aren't running 5,000 or more RPM's and idling at 1200. But they are good reliable carbs for most street to boat applications.
And I WISH my boat had a Mopar in it. I'd be a lot happier, I currently have automotive 361, 383, and 440 big block dodge motors, and a small block 360. Plus plenty of parts to fix or upgrade them. The 302 is my first Ford and I know it's a good motor, but so many little things are different on it from Chevy/Dodge that is annoys me. The cylinder numbering kills me. Anyways, I wish Ford wasn't so common/popular in the Correct Crafts, I'd much rather own a Chevy or Dodge motor.
Posted By: Donald80SN
Date Posted: February-16-2018 at 2:00am
Box up the carb and send it to the following: Carolina Carburetor Specialist 1020 Princess St. Wilmington, NC 28401 910-762-4695 Ask for Butch It will be plug N play and he remanufactures it and he does a bench flow test to dial it in. it simulates an engine so it is all ready to go when he is done. Not cheap, but done correctly and one less thing to worry about. Butch is the man.
JMO,
Donald
------------- 1980 Ski Nautique SOLD Back to Cypress Gardens 2002 Sport Nautique, GT-40, FCT2, Cover Sports, Tower Bimini, Inc., Wet Sounds Audio System, Star Gazer Wake Edition S. 1968 Ski Nautique, Project.
Posted By: rosconole
Date Posted: February-16-2018 at 3:13am
Put it on craiglist, go buy at Holley. Don't waste your time and money messing with a carter, their fuel pumps are junk too, not just the carbs.
------------- 1989 ski nautique ,1991 barefoot nautique, 1993 Mustang Cobra 1998 5.0 Magazine shootout invitee
Date Posted: February-16-2018 at 9:11am
| Better speak for yourself!
Shame on those who say to replace with a holley or “send it out”. The AFB is well suited to the ‘72 340 that it will be sitting on, and carb rebuilds aren’t rocket science. Keep after it, Chris.
Posted By: phatsat67
Date Posted: February-16-2018 at 10:31am
rosconole wrote:
Put it on craiglist, go buy at Holley. Don't waste your time and money messing with a carter, their fuel pumps are junk too, not just the carbs. |
I've had a Carter high flow mechanical pump on my car for 11 years without fail ethanol fuel and all. Couldn't count how many runs to 6000+ rpms it has seen. Carter has always and still supplies the low pressure fuel pump on HO carb PCM/all efi prior to 07. They are extra reliable and only fail when they get pretty darn old. The ethanol is to blame for that I believe.
The new Edelbrock carbs are meh. A Carter setup properly is great on stockish engines or ones that have a lower under hood operating temperature I.E. boats.
They get cranky when they get too hot. They have a fairly small fuel bowl and suffer from vapor lock issues or fuel slosh on cars. Hard braking/cornering makes them act up/stall etc. Boats lean when they turn so it keeps the fuel where it should be. My buddies 440 runs great with a Carter and so does Joe's Wildcat.
Posted By: baitkiller
Date Posted: February-16-2018 at 10:46am
Have not touched my Weber / AFB since the day I installed and tuned it. Not one fuel leak, no blown power valves, no starting issues. Nada, it just runs perfectly every time. It seems to make decent power as well., A couple people here have run my boat. Think its well over 4 years now. Just saying.
I cant remember ever getting that kind of reliability from any other carburetor.
------------- Jesus was a bare-footer.............
Posted By: Riley
Date Posted: February-16-2018 at 11:17am
We've had mixed results with them. Our 312 has a new Edelbrock and runs great right out of the box. We tried 3 different Edelbrocks including one brand new one on a very tired 318 and none of them ran as well as the original old Carter. We had 2 on an FE we have and they never ran good at top end, although that could have been attributed to the fuel pump. I swapped out the Edelbrock for a Holley and a new fuel pump and the engine now runs great. The guy that runs the Chris Craft Commander site which is the authority on the Ford 427 marine engine swears by the Edelbrock. I don't have a preference, other than if it runs good, I like it.
Chris, I'd stick with that Carter for your boat.
Date Posted: February-16-2018 at 11:37am
Bruce, generally a Carter was tuned exactly to the engine it was meant to be on.
Edelebrocks are just set up to generally fit an engine of said displacement. Which is why the correct Carters are usually great and Edelbrocks are so so.
They are much harder to tune than a Holley. There is more info on how to properly set up a Holley for our applications and Holleys are more forgiving in the tuning department.
The Carter has to have the secondary air door weight tuned based on the engine it is installed in which requires grinding the weights. They also have springs that operate on engine vacuum that control the stepped rods into the primary circuit jets. Those can be tuned with a springs and also with rods that have a multitude of step options/diameters. Then you have the jet's themselves. There is also a 3 hole adjustment on the accelerator pump plunger.
If all of those things aren't working in perfect harmony on a Carter you'll get something that isn't seamless. As long as the engine is close to as designed spec the Carter should bolt on and work just fine. Start tuning them and things get complicated.
Posted By: Riley
Date Posted: February-16-2018 at 12:16pm
Zach, I'm surprised at all the on line engine builders that show them on their engines. I find those 2 idle screws don't do anything unless you turn them so much the engine runs crappy, then I set them back where they were. Sounds like you are the Carter guy!
Date Posted: February-16-2018 at 1:28pm
Eh, I have a general dislike for Edelbrock because of the reasons above. Carters can be good but Holley's are the choice for a performance build that changes things like camshaft and jetting etc.
Close to stock engine with a Carter just rebuild it with the proper parts it came with and you are good to go.
The PO of Dave's 440 Arabian installed a fresh Eddy when the Carter wouldn't work. Edelbrock sucked. I opened the Carter and found that poor quality needle and seats had been used that wouldn't seal properly. I checked the float levels/cleaned it all and installed the fresh needle and seats and it ran like a top.
I think it turned around 4900 rpms and ran 52 ish on my GPS. Might go faster with more prop. I forget where I set total timing but he nabbed up 2 sets of NOS correct point's for the thing. It had some wonky ass point installed that I had to bend to make the dwell correct.
Posted By: woodyelc
Date Posted: February-16-2018 at 1:48pm
Have over 50k mile my street rod and never had to adjust the Edelbrock. Just installed a new 318 in a 1972 and had the Carter AFB rebuilt and it will start without throttle cold every time and runs like a top.
------------- woodyelc
Date Posted: February-16-2018 at 7:16pm
rosconole wrote:
Don't waste your time and money messing with a carter, their fuel pumps are junk too, not just the carbs. | Wow, I guess I had better start to worry about that "junk" Carter fuel pump that's on my 312. It's 54 years old and never been touched so it may go at any second.
Date Posted: February-17-2018 at 2:37am
Oh my. I didn't know the AFB was such a hot topic. Honestly, I though the carb was a goner the second I lifted the doghouse on the promo. It was covered iin fuzy corrosion and the insides were full of tar. After a little research, it seems like the AFB complements the 340 like peanut butter and jelly. It was convincing enough for me to tear it open and start a few days of cleaning.
Long story short, this carb has come a long long way from being scrapped. I definitely want to give it a fighting chance at running again. While I'm not a carb expert, I have rebuilt dozens, and I'm looking forward to seeing what this girl can do. It's intimidating with all the external and internal moving parts. Sort of reminds me of a Rube Goldberg machine.
If I can't get this one working, I would look to replace it with another AFB.
Posted By: MrMcD
Date Posted: February-17-2018 at 3:07am
My buddy has a 1972 340 4 speed Challenger. We put a Carter AFB on it at rebuild of the engine. 10.5 compression, polished and ported X heads, headers nice Cam. When we took it to the dyno test that engine screamed to 6,000 where my buddy decided to stop. Made 320 HP at the rear tire. Would be around 400 at the crankshaft. The cool part was the dyno operator showing us the fuel curve and commenting that he had never seen a Carb give such a nice even fuel curve from idle to 6,000 RPM. Put up numbers nearly as good as fuel injection on his car. Experience has shown me you can remove a Carter on a 400 HP small block and bolt on a new Holley and pick up 5 HP. Maybe 7. At the drag strip a Holley has a very slight known advantage and earned the performance reputation. On the street or in a boat there is nothing wrong with running a Carter. We ran a Carter 625 on my brothers jet boat with a 460 for years. His pump limited RPM to about 5,200 and the Carb worked perfectly.
