2016 SAN winterizing help
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=42052
Printed Date: April-29-2024 at 2:03pm
Topic: 2016 SAN winterizing help
Posted By: KLS1969
Subject: 2016 SAN winterizing help
Date Posted: October-17-2017 at 11:43am
Any help on this would be great!
Posted By: quinner
Date Posted: October-17-2017 at 12:37pm
You should have the blue plugs, remove each one and place in the receptacle, once all slots are full and you should be drained.........unless you have a heater or shower?? What motor? Open or closed cooling?
Posted By: KLS1969
Date Posted: October-17-2017 at 2:24pm
Stock motor with a heater (5.7l) thanks
Posted By: KLS1969
Posted By: quinner
Date Posted: October-17-2017 at 7:25pm
You will need to remove a heater hose and then blow the water out with lungs or light compressed air. The top line at the intake manifold will be easiest to get to, remove it and with the JTube plug removed just blow the water out thru the line. Once drain is complete replace all plugs and its up to you, either do a pour in backfill per the owners manual or use the suck up method to get anti-freeze throughout the system.
Date Posted: October-17-2017 at 7:40pm
quinner wrote:
Once drain is complete replace all plugs and its up to you, either do a pour in backfill per the owners manual or use the suck up method to get anti-freeze throughout the system. | I'd like to emphasize a complete drain is important.
