dash panel breakers
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=39466
Printed Date: April-28-2024 at 12:29am
Topic: dash panel breakers
Posted By: velde99
Subject: dash panel breakers
Date Posted: July-25-2016 at 1:57pm
I have a 1991 dash panel I have been fixing up. Most of the breakers seemed to not work the intended features like the :bilge pump, blower, lights and more. The ignition worked and that was about it. I have replaced the right side with the correct original amperage breakers. The left side has 3 10Amp breakers- which I am now out of. I do have 3 NOS 15 amp breakers, I was wondering if I could use those instead. It is for the Navigation lights and the two accessories breakers. Just don't want to spend $100 if I don't need to. Any one have any input on this?
Posted By: Orlando76
Date Posted: July-25-2016 at 2:06pm
Mmmmm, 15 is close enough to 10.
------------- Please support The Cystic Fibrosis Foundation 1976 Ski Nautique 351 Escort 1993 Ski Nautique purple and black 351 HO PCM
Posted By: C-Bass
Date Posted: July-25-2016 at 2:11pm
Will it switch on/off -> Yes
Could it cook your wiring in the event of a short before tripping the breaker potentially starting a fire -> Yes
------------- Craig 67 SN 73 SN http://www.correctcraftfan.com/diaries/details.asp?ID=6103" rel="nofollow - 99 Sport 85SN
Posted By: velde99
Date Posted: July-25-2016 at 2:15pm
Todd- so the Mmmmmmm. part of your comment. You think 15 would be ok? Someone told me can always go up- not down. I actually don't have anything running off accessory breakers other than original stereo.
Date Posted: July-25-2016 at 2:19pm
They used to put copper pennies in the old Edison base fuse holders too!!
Posted By: velde99
Date Posted: July-25-2016 at 2:20pm
Craig- so what your saying is stick to the original amps and spend the $100😜
Posted By: velde99
Date Posted: July-25-2016 at 2:21pm
Pete- would love your thoughts. Was gonna say "2 cents" with your penny comment😀
Date Posted: July-25-2016 at 2:26pm
Ultimately what dictates breaker size is wire size. Seems to me IIRC my entire 93 is wired in the same 16ga wire except the teeny 10ga feeding the dash, despite the breaker size. So if it were 16ga wire, I wouldn't think twice about using a 15 amp breaker. It's not correct. Like you said, accessory switches aren't used, how often do you use the bow light? put the 15's in and as often as you're parting out boats next week you'll have new tens and then I'd correct it.
Posted By: velde99
Date Posted: July-25-2016 at 2:29pm
Date Posted: July-25-2016 at 2:34pm
velde99 wrote:
Pete- would love your thoughts. Was gonna say "2 cents" with your penny comment😀 | Rod, As Todd mentioned, it does come down to wire size. It's like putting a 20 amp breaker in place of a 15 in your house but the circuit is only wired with 14 ga. I don't want to recommend going to the 15 when the originals were 10. I'm not a big fan of those breakers anyway. Sometimes they work and sometimes they don't!!
Posted By: Air206
Date Posted: July-25-2016 at 2:37pm
I'll answer for Pete - since Pete let me down...............
Get out the VOM!
If you could jump the breakers and have it all work, replacing the breakers should fix you up. If they don't work jumped....Trace the hot from the ignition breaker or the ground at the dash (a common issue).
------------- https://tinyurl.com/y6t5e3bu" rel="nofollow - 04 Air206 http://tinyurl.com/9urzgls" rel="nofollow - 91 Barefoot 78 SkiTiq
Posted By: Trader144
Date Posted: July-30-2016 at 9:38pm
Last time I looked the manufacturer still makes them. Make sure you get both a switch and breaker combination. It was worth the extra $7 each for me to just by them from skdim.com
