1986 project assembly
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=35624
Printed Date: April-29-2024 at 9:32am
Topic: 1986 project assembly
Posted By: cueball
Subject: 1986 project assembly
Date Posted: March-26-2015 at 7:44am
Hi All, Well I have started my project I recently acquired. Here are some pics when I first started.
I stared first with the trailer, new wiring, lights, wood and carpet.
I even replaced the existing wheel wells due to the staples on the top edge.
Finished
------------- Shawn 1986 SN 2001
Posted By: cueball
Date Posted: March-26-2015 at 7:54am
As I was going over the boat this is what I found.
After I saw this I lifted up the boat and checked everywhere to make sure there wasn't any more damage hiding. This is the only one and it is right under the stringer....so out came the grinder...
Once I started grinding I realized it wasn't as bad or deep as it seemed.
Two layers on
Third layer
Sanded down
Painted
Date Posted: March-26-2015 at 8:02am
Shawn, Since you mentioned the stringers, have you checked their condition?
Posted By: cueball
Date Posted: March-26-2015 at 8:09am
Then next was installing the Rope in the Rub Rail and adding pinstriping between the colors. I found some tips on this site on how to install the rope, I started with 1/2" rope from home depot and used a 1/2" copper pipe to slide it in, it took less that 1/2 hour to do. The side in the shade was harder than the side in the sun. It was 75°f that day.
Then I decided to sand down the deck and apply teak oil to it...it had some varnish, gooey, stuff on it that didn't look good.
Back end with decals added
Before
After
Posted By: cueball
Date Posted: March-26-2015 at 8:15am
Yes I did check the stringers by tapping a deep socket all around and they sound solid. the only bad spot in the floor is around the ski pole which I will be replacing soon.
Posted By: cueball
Date Posted: April-27-2015 at 5:39pm
Here is some updates
Before
After
Some side graphics
And my parts for the engine finally came!
Posted By: cueball
Date Posted: April-27-2015 at 6:52pm
So I got a new press
And this is my helper who helped assembled the press.
New shaft bearrings
So I pressed out the old, and got some great advice In the General Question forum for adding dimples to the new bearings.
Made marks on the bearings and the shaft to line up both bearings.
Then I used a drill bit to dimple the bearings, notice the tape on drill bit for how deep to drill. Then I used blue lock tight for the set screws.
Engine essembly time!
Well I got the camshaft, crankshaft installed, pressed the pistons to the connecting rods, rings on the pistons and one piston installed. Hopefully I can get some more done next weekend...as long as the honey-do-list doesn't get too long!
Posted By: skutsch
Date Posted: April-27-2015 at 7:45pm
Any upgrades to the motor?
------------- Our http://www.correctcraftfan.com/diaries/details.asp?ID=4669" rel="nofollow - 98 Sport Nautique My Dad's 63 Ski N
Posted By: peter1234
Date Posted: April-27-2015 at 8:46pm
did you bore the block tank cleaned and new cam bearings?
------------- former skylark owner now a formula but I cant let this place go
Date Posted: April-27-2015 at 8:47pm
oh and whats the bike (2 wheeled) in the background ?
Posted By: cueball
Date Posted: April-27-2015 at 9:38pm
skutsch, mild cam from Sealed Power and bored .060 over
peter1234, All machine work and cleaaning done, new bearings for crank, rods and camshaft. Also a new oil pump. Reconditoned carburator from Eldelbrock has been ordered. Heads are rebuilt too, nothing special.
1999 Harley Night train.
Posted By: cueball
Date Posted: May-17-2015 at 2:03pm
updates on engine assembly
mini me helping
time to put the heads together
getting there
Posted By: cueball
Date Posted: May-27-2015 at 2:38pm
Rebuilt the Impellar
Engine coming together
Fixing the wiring hack job from PO
Trim the Flexplate
Engine mounts came in the mail today, bought them from a CCF member.
Posted By: JoeinNY
Date Posted: May-27-2015 at 3:13pm
Can you get a reverse rotation cam from sealed power or are you going with standard rotation?
1967 Mustang 302 "Decoy"
Posted By: scootdogydog
Date Posted: May-27-2015 at 3:18pm
take that fram off now -- it's junk!
------------- http://www.correctcraftfan.com/diaries/details.asp?ID=7183" rel="nofollow - 1999 Python 1980 Ski Tique 1968 Mustang WIP
Posted By: AAM196
Date Posted: May-27-2015 at 3:40pm
Nice thread Shawn... motor looks to be sorted nicely!
I think the little lady wants to be in the water by mid June... keeping daddy focused!
Good luck!
Posted By: cueball
Date Posted: May-27-2015 at 5:02pm
The cam I believe is a Comp Cam, the previous owner(s) had torn it all apart, had the machine work done and had ordered the bearings, cam oil pump. I had to order pistons and gasket kit. the cam is a reverse rotation, when I read about it I panicked and started doing the research, the crank casting is reverse rotation, so I held the cam up to the motor and spun it around and checked the lobes and it is reverse, double checked when I adjusted the valves.
Funny this is I just was looking up fuel filters and I was amazed at how everyone does not like fram, even read some good reasons why they are junk, so I will change it.
Yes the little one is looking forward to being on the water, she/we had a blast last summer with a friends boat.
Date Posted: May-27-2015 at 7:22pm
cueball wrote:
Yes the little one is looking forward to being on the water, she/we had a blast last summer with a friends boat. | Shawn, Hurry up so you can get her out on ski's! NOT TUBES!!
The build is looking great.
Posted By: SNobsessed
Date Posted: May-27-2015 at 8:13pm
Just wait until the day she pulls you skiing. Way cool feeling!
Posted By: cueball
Date Posted: May-29-2015 at 1:32pm
More stuff bolted on the engine, new engine mounts sand blasted and installed, also tranny is installed now. Soon engine will be in the boat.
Posted By: Hollywood
Date Posted: May-29-2015 at 3:20pm
Is that a 1.25" hose clamped down to a 1" strainer outlet barb? The hose looks really squeezed. Make sure that's the right size fitting, highly susceptible air leak otherwise.
Posted By: cueball
Date Posted: May-29-2015 at 4:48pm
you are correct, I am going to change that and install a hose connection there, that was the previous owners handy work. I've already fixed 3 other bad connections just in hoses and have ordered the water pump hose to fit correctly.
Posted By: cueball
Date Posted: June-14-2015 at 9:17pm
Sanding down the floor, still had alot of carpet still glued to it
Cut out a bad patch
Painted some sealer for some extrax protection
And of course I had a helper
I pulled off the siding to slide some 10ft 4x6's in the rafters
Time to install the engine
Had to deflate the tires so the engine could clear the boat
Engine is in, waiting for some parts I have ordered, hopefully I will be starting it this weekend Im glad I decided to change the fuel filter
Posted By: cueball
Date Posted: June-22-2015 at 11:55pm
Time to start the engine
But some idiot (NOT ME) had bolted the platform thru the gas tank!!!!! I poured about 2 gallons of gas in the tank, then I heard it running out the drain to the ground.
What a bummer!
Posted By: gun-driver
Date Posted: June-23-2015 at 9:14am
It can be welded, no biggie. At least they bolted it down when I got my '85 every time I filled it up and started driving I would get a strong gas odor. After some investigation I found the PO never bolted it back down after removal and the only thing keeping it in place was the connection at the filler neck. Needless to say the neck cracked around the base and when you would turn hard the tank would shift and the crack would open a gas would slosh out.
Posted By: cueball
Date Posted: June-30-2015 at 1:46am
That sucks gun-driver
Posted By: cueball
Date Posted: June-30-2015 at 2:07am
So on Friday I picked up my gas tank from the local welder here in Vacaville, Webbs welding. Highly recommend them. And hopefully will get the boat started today
So I get the gas tank installed and try to fire up the boat!!! I'm so excited and nervous! So after a few attempts to fire her, I decided to check TDC. I popped off the dizzy cap and bumped the starter to get to TDC and I realized something not good.......the dizzy is spinning clock wise........ First thought....oh crap Second thought....I can just switched the wires around Third thought....what about the oil pump....... So I pulled the dizzy out and tried to prime the pump clockwise and it doesn't work.....Major bummer. So I posted in general questions "Help!!! Timing Issues!!!" if you want to look at it. So basically I have the wrong camshaft and distributer....long story, see help!!! timing issues!!! post So I'm taking a break from this project due to vacation coming up. I will be ordering a camshaft after my vacations are over in the middle of August (hopefully sooner)
Date Posted: June-30-2015 at 3:06am
I have a RR stock cam I'll let go cheap.
Posted By: cueball
Date Posted: March-29-2016 at 5:40am
Well it has been a while since I been on here, but I'm back at working on the boat. This project has been madding with the whole reverse/standard rotation! Especially since this project has parts that differ from original.
Tine to pull the engine and verify the crank wick lines one more time before I make the next move.
So, I was wrong, the wick lines are standard rotation, also the transmission pump is set up for LH rotation, and this project came with two starters and the extra one is a standard rotating starter...... So I have a standard rotation engine.... Well while the engine is out I decided to install a oil drain hose, I had the wrong dip stick, so I found on this site a oil capacity test they did, and I followed it and fabricated the dipstick.
I also replaced the front main seal to a standard rotation seal
I also got the correct thermostat housing from a member and ordered the correct thermostat. I also ordered a new water pump, just because of the whole reverse/standard rotating thing. So the engine is back in the boat, and tomorrow evening I am picking up my carb and hopefully I will get it running on Wednesday!
Posted By: cueball
Date Posted: March-29-2016 at 6:09am
I also put new bearings, rims and tires on the trailer.
Glad I did, Found that the rear seals were leaking and the brakes were covered in grease. the other side was worse.
So I cleaned everything up and put new studs in the drums.
Drilled out the center caps
All done. So while I was working on this I noticed one of the leaf springs is sagging and upon closer inspection, one leaf is cracked and broken, and the others are buckling. so new leaf springs are on the way.
Posted By: Duane in Indy
Date Posted: March-29-2016 at 6:58am
cueball wrote:
The cam I believe is a Comp Cam, the previous owner(s) had torn it all apart, had the machine work done and had ordered the bearings, cam oil pump. I had to order pistons and gasket kit. the cam is a reverse rotation, when I read about it I panicked and started doing the research, the crank casting is reverse rotation, so I held the cam up to the motor and spun it around and checked the lobes and it is reverse, double checked then I adjusted the valves.. |
Your crank and cam are definitely STANDARD ROTATION. So basically all you needed to do is replace your starter with the proper one, and redo your plug wires on the cap . Below are pics of RR parts. Good luck with your project. Sorry, I just joined this past Fall and did not see your pics till today.
Posted By: Smithfamily
Date Posted: March-29-2016 at 7:04am
SNobsessed wrote:
Just wait until the day she pulls you skiing. Way cool feeling! |
Yes it is!!
------------- Js
Posted By: cueball
Date Posted: April-08-2016 at 8:22am
Well I got her running!! But when I went to put the tranny in gear, nothing happened......At that moment I shut her down and pull the tranny to check the pump.
Here is a picture pre instalation
Now I did see a arrow on my transmission, but I got all confused with the whole LH, RH rotation and did a internet search. (It had been a couple of months since I had to realy think about it.) I went off of this pic I found on the internet and was like "Its already LH rotation!!" just from the image, didn't notice the arrows.
Well I was wrong. This RH, LH, reverse, standard, in front of the motor, behind the motor can be maddening!!!
So the transmission is in and and it goes into gear, I still need to fine tune the engine and I have a prop on its way. Hopefull I can put it in the water soon to test it out.
Here are some updated pics of the boat I got the tower, cabin speakers, radio and hull numbers installed.
Date Posted: April-08-2016 at 10:21am
Shawn, It's great you are making progress. It won't be long before you can enjoy some water time and appreciate all the effort you've put in.
Don't worry about the LH, RH issue. Many including myself struggle with it as well. There are times when I have to close my eyes and imagine in my mind the rotation!
Posted By: cueball
Date Posted: June-25-2016 at 4:18am
Update, Sorry its been a while, in the middle of April till June 15 I was on a project at work working nightshift, 6 days on, one day off, 13 hour shifts. So the last 9 days (working 4 of those days) has been a mad dash to get it finished for our camping trip next tuesday June 28th! Here is some of the things I've done
When I did the wheel bearings, I noticed the leaf springs were cracked, so I did replace the leaf springs, both sides.
And the bushings were very worn out,
And I replaced the prop shaft. Here is how I got the coupler off.
And trying to get the new coupler on was a PITA. I ended up putting the old one back on for now. Heated it up in the oven and the old one went on easier than the new one.
Made a jig to bend 3/4 inch conduit for the bimini top I made
And I used a conduit bender to make the 90° bends
Bimini frame on the boat
Time for carpet
Carpet complete
And yesterday was the first time on the water! Had to ajust the shif linkage, snuffing box packing and tighten down a few hose clamps and the carb to the intake. other than that she ran great!
Got the rest of the interior, the canvas for the bimini, and surf racks installed today! Im ready for our trip!
Date Posted: June-25-2016 at 3:03pm
Nice boat!
Posted By: Fabcon
Date Posted: June-25-2016 at 7:46pm
Very nice project, way to stay with it, now the fun begins.
------------- 1976 Ski Nautique 351 Escort 1984 Barefoot Nautique (Parting Out)
Posted By: Gary S
Date Posted: June-25-2016 at 8:22pm
Nice job on the top,it really worked out nice. I have to ask about the registration numbers though, it looks as if you put the serial number of the boat on. Don't you have to register the boat with the state and they issue you a number much like your car gets a license plate? Don't want you getting stopped!
Posted By: cueball
Date Posted: June-25-2016 at 10:36pm
Thanks for pointing that out Gary.....Im gonna double check that! I think I made a mistake there.
Posted By: cueball
Date Posted: June-25-2016 at 10:37pm
Thank you for the comments!
Date Posted: June-26-2016 at 4:10am
Shawn, You certainly put plenty of nice work in your boat and now I wish you plenty of great times on the water.
