URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=33410 Printed Date: April-29-2024 at 3:01am
Topic: Bent shaft?Posted By: Kristof
Subject: Bent shaft?
Date Posted: April-22-2014 at 7:44am
Pete, Tim and other specialists...
A video tells more than a thousand words, so I took my smartphone:
So, is my shaft bent? When I put a long screwdriver next to the shaft (tip pointed on the bilge floor and screwdriver shaft next to prop shaft, for lack of a better explanation by a non-english speaking forreigner )I can see it move back and forth a little (read: half a millimeter)
There is no play whatsoever in the strut, prop looks fine and shaft moves nice and freely (checked alignment last week). I have a negligeable vibration between 2100 and 2150 RPM (between 30-35 KPH, 19-21 MPH)...
Should I start to panic by now...??
------------- - Gun control means: using BOTH hands! - Money doesn't make one happy, but when it rains cats and dogs, it's still better to cry in a Porsche than on a bicycle...
Replies: Posted By: ny_nautique
Date Posted: April-22-2014 at 8:33am
Here's the video:
------------- - Jeff 1999 Ski Nautique
Posted By: Kristof
Date Posted: April-22-2014 at 10:48am
Oops, sorry, my bad... Edited my post.
Thanks Jeff
Posted By: phatsat67
Get a dial indicator Kris. That will tell you for sure and you'll use it again with all your mechanical skill.
Posted By: Kristof
Date Posted: April-22-2014 at 11:00am
Ha, that's one of the answers I expected Zach
But, before I spend yet more money on the B(reak)O(ut)A(nother)T(housand), what is your opinion on what you see in the video?
Date Posted: April-22-2014 at 11:17am
It looks like its moving the shaft log around a bit but that could be inconsistency in the shaft packing? The spec for tolerance in a shaft is .003 or less run out. So its a pretty tight spec but a little room for error.
Date Posted: April-22-2014 at 8:12pm
Kristof, I agree with getting the dial indicator out. Besides the shaft, the coupling could be an issue too. Ether with a bad fit to the shaft or a coupling face that isn't running true to the shaft.
Posted By: Kristof
Date Posted: April-23-2014 at 7:15am
So dial indiactor it is... I'll get back to ya
