Need to watch those wheels!
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=2683
Printed Date: May-15-2024 at 7:56pm
Topic: Need to watch those wheels!
Posted By: pswann
Subject: Need to watch those wheels!
Date Posted: November-03-2005 at 5:14pm
The nut was the only thing left when I got back from the house. No inner race outer race, no bearings, grease seal just hanging and I didnt feel a thing. It was a new hub so I think there may have been some spindle damage before. I am glad I didnt loose the wheel! Just finished installing a new 3500 lb axle complete with bearing buddies.
Posted By: 6strings
Date Posted: November-04-2005 at 10:30am
Pswann,
I am planning on replacing the axle on my cc trailer as well. I had a bearing failure that scarred up the spindle some. Seems to be o.k. but I don't trust it. Do you mind advising where you got the new axle?
Posted By: pswann
Date Posted: November-04-2005 at 11:10am
Glad you asked! These guys are better than shirt pockets. I got the axle, u bolt set, bearing buddies and shipping for 150 total including tax. I think that is real cheap compared to magnum trailers.
http://www.etrailerpart.com/
They got it out the same day and I had it the next. I have to take the ups tag and shipping tag off it so I may click a picture and post it just so you can see it.
Posted By: Bill336
Date Posted: November-04-2005 at 11:25am
I bought my cla** V trailer hitch from etrailerpart and they were fast and cheap. I was very impressed with them.
Posted By: pswann
Date Posted: November-04-2005 at 6:56pm
Does this look beefier or what! I am pleased with it. Havent bounced it around yet but will Sunday when I do an engine alignment.
Posted By: woodyelc
Date Posted: November-05-2005 at 12:43pm
THAT TRAILER NEEDS SPRINGS AND YOU NEED TO WELD THE SPRING PLATE TO THE AXLE.
------------- woodyelc
Posted By: pswann
Date Posted: November-05-2005 at 5:41pm
On the to do list. Had to get it together to take it to get it welded. The springs work fine. Thanks for the part, whats your email address?
Posted By: 6strings
Date Posted: November-07-2005 at 10:54am
I don't get it. Why does it have to be welded, and what's wrong with the springs? Thanks!
Posted By: pswann
Date Posted: November-07-2005 at 8:33pm
I will answer the welding part and wait for woody to tell why the springs need to be replaced.
The spring plate keeps the axle from spinning when your driving. All I need to do is have it tacked so it wont spin. I will get it welded when I drive by a welder. Maybe it is because the springs are old. Everything on this boat is old. Check out the mounts!
But a wire wheel and some cleaning and you still have life in the old parts.
Posted By: 6strings
Date Posted: November-08-2005 at 7:19am
Nice! I understand now about the axle turning. In fact, your old axle, and my axle, is square so the welding wouldn't be necessary if replacing with another square one???
I really need to put some time and money into my trailer. I hope to strip it, sand blast, replace the axle and the bunks, and paint it this spring.
Posted By: pswann
Date Posted: November-08-2005 at 7:28am
Welding the plate will be cheap. Finding a square axle, I didnt even see one on my searches. You can tell from my pics that the round axle is much beefier than the square one. A 150 dollar fix in the boating world is a cheap fix. Since it is such a small trailer it shouldnt take you too long.
Posted By: woodyelc
Date Posted: November-09-2005 at 9:18am
THE SPRINGS HAVE LOST THE ARCH WHICH GIVES YOU THE SOFT RIDE. YOU LOSE THE MOVEMENT OF THE SPRING HANGER. THE ORGINAL AXLE WAS A SOLID BAR OF STEEL THAT HAD THE SPINDLE MACHINED ON THE END. THAT AXLE WAS RATED AT 3500 LBS. THE MOUNTS LOOKED GOOD AFTER YOU CLEANED THEM. DON'T FORGET TO REPLACE THE RUBBER BUSHING IT HELPS KEEP THE MOUNT STABLE SO THE ALIGNMENT WILL NOT CHANGE. MAKE SURE YOU ALIGN THE MOTOR WHEN YOU ARE DONE WITH THE MOUNTS.
Posted By: Bob's2001
Date Posted: November-09-2005 at 4:47pm
Where can I get the bushings for the trans & motor mounts? I have seen the whole mount for sale but not just bushings.
------------- Bob Ed
83 2001
Posted By: markb
Date Posted: November-09-2005 at 4:54pm
woodyelc, good info there.
One suggestion..
caps lock off! :-)
Posted By: 79nautique
Date Posted: November-10-2005 at 11:22am
also there is a e-clip/snap ring missing that holds the bushing in place and from poping out the top like the old one did.
Posted By: Stan C
Date Posted: November-10-2005 at 9:26pm
Bob"s 2001
I recently rebuilt all 4 of the engine and trans mounts on my boat and was able to get all the bushings, nuts and washers direct from PCM.
------------- Stan C
Posted By: S.T.
Date Posted: November-17-2005 at 11:17am
pswann,
What kind of boat/trailer is that? On my trailer (1986 Ski Nautique) the axle mounts on top of the springs and dips down in the middle so the tracking fins can clear. If I used that axle, I'd have a "monster trailer", hung-up tracking fins, or possibly both.
...just curious. I don't know what I'd do if my spindles needed replacing.
Posted By: pswann
Date Posted: November-17-2005 at 11:40am
76 tique, this axle increased height by 1.5 inch. Keep your bearings in good shape and you wont have to replace the spindle.
Date Posted: November-17-2005 at 1:32pm
StanC, Thanks for the info. I found them at Palmer Power in Houston. They are a Velvet Drive dealer.
83 2001
