Sticker glue
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=12174
Printed Date: May-15-2024 at 10:17am
Topic: Sticker glue
Posted By: ccfl08
Subject: Sticker glue
Date Posted: October-16-2008 at 11:36pm
The previous owner removed most of a sticker, but the glue is still on the gelcoat. What should I use to remove the glue and not damage the gelcoat?
Posted By: Sam B
Date Posted: October-17-2008 at 12:30am
Mads,
This product works good and won't damage your gell coat.
3M™ 6041 Adhesive remover, 24 oz aerosol. ...
Check it out on 3m.com
Sam
------------- Loud pipes save lives!!
2011 Green Lake Reunion Best of Show.
%20http://www.correctcraftfan.com/diaries/details.asp?ID=3391&sort=&pagenum=3&yrstart=1973&yrend=1973" rel="nofollow - Sam's 73
Date Posted: October-17-2008 at 8:47am
cc,
First I'd like to welcome you to CCfan. Did you just find the site or just new to posting.
Not much will hurt gel coat. A methylene chloride based paint and varnish remover will soften it if it's on the gel for a long time but we aren't talking about going to that extreme. I'd use acetone to removed the adhesive. It will be quicker as it will dissolve it better than the 3M remover. The 3M is a citrus based "solvent" that really isn't very strong so it can be used on painted surfaces safely.
Posted By: ripster92
Date Posted: October-17-2008 at 12:22pm
8122pbrainard wrote:
cc,
Not much will hurt gel coat. A methylene chloride based paint and varnish remover will soften it if it's on the gel for a long time but we aren't talking about going to that extreme. I'd use acetone to removed the adhesive. It will be quicker as it will dissolve it better than the 3M remover. The 3M is a citrus based "solvent" that really isn't very strong so it can be used on painted surfaces safely. |
I'll second the acetone. Keep the rag wet and use plenty of 'em. It will just smear around if too much of the sticker accumulates on the rag.
------------- 1992 SN Black w/ Yellow
Posted By: farmer
Date Posted: October-17-2008 at 10:15pm
I've used WD40. Works and it's cheap.
------------- Watch your fingers.
Posted By: ccfl08
Date Posted: October-18-2008 at 6:51pm
Thanks for the suggestions. I tried Acetone and it worked great.
Date Posted: October-20-2008 at 9:20am
farmer wrote:
I've used WD40. Works and it's cheap. |
Gary,
I've got to ask! You must be buying WD40 by the gallon! I was over at the hardware this weekend and took a look at the prices. WD40 is basically mineral spirts with some small amounts of friction modifiers. Compare and calculate the per oz. price some time - I did!!
