One for the tranny boys...
URL: http://www.CorrectCraftFan.com/forum/forum_posts.asp?TID=10216
Printed Date: May-12-2024 at 10:03pm
Topic: One for the tranny boys...
Posted By: Kristof
Subject: One for the tranny boys...
Date Posted: April-21-2008 at 8:30am
Eric and other tranny guru's...
When checking the shaft seal last sunday, I noticed that, when the engine runs at idle (800 RPM) and the handle is in neutral, the shaft keeps turning slowly (plus minus one RPM per second). Is this normal? If not, how to fix this?
Thanks,
Kristof
------------- - Gun control means: using BOTH hands! - Money doesn't make one happy, but when it rains cats and dogs, it's still better to cry in a Porsche than on a bicycle...
Date Posted: April-21-2008 at 9:03am
How much would it cost to ship a trans from Belgium to Ohio?
Kristof, I think the slow rotation is normal. I see it all the time. Eric, Isn't some just caused by the oil shear between the plates?
Posted By: Kristof
Date Posted: April-21-2008 at 9:39am
8122pbrainard wrote:
Kristof, I think the slow rotation is normal. I see it all the time. Eric, Isn't some just caused by the oil shear between the plates? |
A buddy of mine here said it could be due to the viscosity of the transmission oil...
But, Pete, it's good to hear that you've seen it also.
Posted By: eric lavine
Date Posted: April-21-2008 at 9:44am
its pretty much normal, what kind of oil are you running Kristof?
Posted By: Kristof
Date Posted: April-21-2008 at 10:10am
Eric, I don't know the brand, but my friend who's a marine mechanic and did the engine overhaul with me, said it's about the best stuff you can get on the market (that's because I damn well told him only the best is good enough for my baby!! )
He got the oil at the CC dealer here in Belgium.
Date Posted: April-21-2008 at 10:29am
sounds like you bought some $12.95 a quart snake oil
Date Posted: April-21-2008 at 10:30am
the best oil to run is dexron mercon $1.95 qt
Date Posted: April-21-2008 at 10:33am
BTW, when you did the engine how many bolts were left over that you figured you probably didnt need anyways? lol
Date Posted: April-21-2008 at 11:07am
eric lavine wrote:
BTW, when you did the engine how many bolts were left over |
It's only a really good mechanic that can make something work with parts left over after reassembly!!!!
Belginian snake oil?? Do they even have snakes??
Date Posted: April-21-2008 at 11:11am
It's only a real good mechanic that can make something work with parts left over after reassembly!!
Posted By: Brktracer
Date Posted: April-21-2008 at 11:22am
You'd better have bolts left over after a rebuild. If not, it's probably because they were dropped in the intake or left in the oil pan. The only way to ensure this didn't happen is to have them left over.
Matt
Posted By: Kristof
Date Posted: April-21-2008 at 11:48am
eric lavine wrote:
BTW, when you did the engine how many bolts were left over that you figured you probably didnt need anyways? lol |
Believe it or not... NONE... go figure LOL
Belginian snake oil?? Do they even have snakes?? |
Yes we do, Pete, we have three species of snakes (only one is dangerous)
Eric, I gave a call to my friend, and this is the oil I have in my tranny at the moment:
http://www.kroon-oil.com/en/products/catalogue/seg_marine/krgo/97/marine/kroon-oil-gear-oils/atf-dexron-2---d/ - Kroon Oils
I hope it will get your approval
Date Posted: April-22-2008 at 12:17am
it says it is a derivative from mountain goats
Posted By: Kristof
Date Posted: April-22-2008 at 5:55am
eric lavine wrote:
it says it is a derivative from mountain goats |
And.........?? Is that bad for the tranny.......? is that what makes my shaft turn slowly at idle...?
Posted By: wakesurfer
Date Posted: April-29-2008 at 8:32pm
Mine spins faster than mentioned above in so called neutral..
Not sure what to do next?
Date Posted: April-29-2008 at 11:09pm
how bad is it spinning? does it want to stall when you put the boat in reverse? it really shouldnt spin at all and is refered to as a clean nuetral.
how many hours? how does the oil smell and look?
Date Posted: April-29-2008 at 11:18pm
Eric, More on wakesurfer's trans here starting about half way through the thread.
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=10055&PN=1 - dry start set up
Date Posted: April-29-2008 at 11:35pm
Pete, how the hell do you keep track of this stuff?
Date Posted: April-30-2008 at 12:56am
Thanks for all the insight. the prop spins one to two revolutions a second, yet I can stop it by hand... the fly wheel that is.
The trans fluid was black to dark dark red. Lots of hours over 1k. didnt smell.
I drained the fluid, put in new fluid w an evil additive. It seems to slow it down a little. The reverse seems like a fast and abrupt transition... from fwd, to reverse - very strong and powerful reverse. The PO said it had been that way for a long time... thanks for telling me now.
Hope to get my cables put back properly into my shifter.
I know this is off topic, but I cant remember how the levers in the inside of the shifter arm were arranged?
such a newbie.... keen though,
jamie
Date Posted: April-30-2008 at 11:53am
alot of times when they slam into gear such as into reverse, the reverse return springs will weaken and the piston shoots out and grabs the plates, this is one of the primary causes for snaping reverse plates in half, it sounds like you can get another season with no major problem, but if the nuetral drag gets worse you have to take care of it, at least for safety reasons
Date Posted: April-30-2008 at 12:53pm
eric lavine wrote:
it sounds like you can get another season with no major problem, |
Eric, He used a additive in the trans.
Date Posted: April-30-2008 at 1:43pm
DC
Date Posted: April-30-2008 at 8:58pm
Thanks for all the help on this and other post.
BTW, what does "DC" stand for?
I assume additives are EVIL.
off for another episode in the boat.
cheers.
Jamie
Date Posted: May-01-2008 at 7:57am
cheers.
Jamie |
Death certificate.
Date Posted: May-01-2008 at 10:22am
then birth certificate
Date Posted: May-01-2008 at 10:23am
thats the first smiley for me
