  New Posts New Posts RSS Feed - Engine Mounts hardware-Atom Skier
56-Atom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 56-Atom Quote  Post ReplyReply Direct Link To This Post Topic: Engine Mounts hardware-Atom Skier
    Posted: October-29-2018 at 3:30pm
I am assessing the condition of my engine mounts as I begin to align the prop shaft and motor. I noticed there is only a single bolt securing the engine to the bushing mount. When looking at newer engine mount options, I noticed a bolt stem with multiple fasteners for adjustment purposes. Am I missing the adjustment hardware or is this the way the 1956 Atom was set up?
56-Atom
https://www.facebook.com/media/set/edit/a.1729455880510267/
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2018 at 3:47pm
John,
You're not missing anything on the mounts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 56-Atom Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2018 at 3:56pm
Thanks, what do you recommend as the best way for alignment with prop shaft.? When I have the wood wedges set in original holes and all mount bolts fastened, I am about .25 too high on the engine output plate.
56-Atom
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2018 at 4:25pm
John,
The wedges need to be moved and lag bolt holes elongated or new wedges made. I find it just as easy to make new wedges, align the engine and then drill clearance holes through the new wedges. Keep in mind you are looking for parallelism between the coupling faces. Also, how's the alignment between the strut and log. That needs to be good first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 56-Atom Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2018 at 4:57pm
Thanks and now that I know I have what I need, I'll start to work on the alignment process. Will keep you posted.
56-Atom
