Slalom course guidelines (driver) |
dgabler
Groupie Joined: June-12-2017 Location: Atascadero Status: Offline Points: 71 |
Posted: June-04-2018 at 5:24pm |
I can find plenty of guidelines / help / suggestions on how to run a course for the skier but I am unable to find much on driver guidelines other than don't tangle the rope in the balls.
are there any suggestions /guidelines that people have for drivers on a course? The only 'training' I can find is this http://www.usawaterski.org/trained-boat-driver-course/ |
91NaughtyQ
Senior Member Joined: July-27-2015 Location: NC Status: Offline Points: 287 |
Pretty easy stuff -- A few guidelines - - These are just my opinions not hard fast rules -
- Stay straight - The skier will tug on the boat a bit - Use the tachometer, not the speedo - (Assuming you don't have perfect pass) You will need to "squeeze" the throttle" the whole time and slightly adjust to compensate for the skier loading up against the boat. - Learn how to turn around "P-Turn" There are diagrams out there for it. - Always idle back to fallen skier - Learn how to keep the skier connected to the line when pausing between runs or taking up rope - This is done by the driver swinging left while the skier swings hard out to the right and then throttling the boat down. The skier ends up in line with the driver(ish) Your job is to keep the boat as straight and consistent (Speed) as possible... Good luck. Gary |
1991 Ski Nautique
(Previous)1984 Ski Nautique 2001 |
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3887 |
I would suggest also going over to www.ballofspray.com. Those guys can also provide some great tips. Be sure to go to the forums.
91NaughtyQ
Agreed. BOS has some great info.
1991 Ski Nautique
Fl Inboards
Grand Poobah Joined: January-20-2008 Location: United States Status: Offline Points: 2065 |
As a Senior AWSA driver my recommendations to a newbe slalom course driver is to get in with an accomplished driver and learn from them. it would only take a time or two but the information that can be shared is invaluable.
driving by hand is a lost art. If you have a boat with out some sort of speed control you are not doing anyone any favors trying to hold speed in the course driving by hand especially if you are new to the course. lots of public lake eddicate involved. don't throw rollers down the course. don't drag your skier during sit down. Even though you may have put the course in it is in public water and you will have to share water time and even the course with others. balance the boat so as the wakes are even. and above all you as the driver are not the most important part of the process, the skier is the most important part you are there for that skier. have fun be receptive to adjustments and be safe! |
