Prop clearance from trailer guard |
Webster
Newbie Joined: November-26-2017 Location: Knoxville Status: Offline Points: 32 |
Posted: April-11-2018 at 6:00pm |
I'm sure this topic has been addressed, but couldn't find any threads. I purchased a '83 2001 with trailer. After I refurbished the SN, there was a vibration at about 30 mph. Looked like the prop had been hit, so bought a new prop. Based on the board experience, i purchased the ACME 540 3 Blade 13" x 12" Propeller.
I just finished installing the prop and it hits the trailer guard (too long by about 1/4 inch. The trailer already has about 2" spacers on each side so the old prop wouldn't hit, but it still scrapes the ground leaving my drive and returning. Anyone have a fix? I saw one guy had removed the center guard and replaced support with two steel bars, one on either side, straddling the prop and the rudder. Thanks for any help. David |
Ski Nautiques deserve a second chance......
Duane in Indy
Sounds like raising the bunks some would help
1978 Mustang (modified) |
Webster
Thanks Duane. Just before I bought the new prop, I had just replaced the bunkers and carpet. I Considered adding a 4x4 on top of the 2x4, but just concerned about the height and strength/stability.
David,
There is a recent thread on the prop guard clearance but even with google, I can't find it. Well, if I remember correctly, the general consensus was to add spacers and longer bolts between the aft mounting point of the guard to the frame of the trailer. |
OldSchoolBlue84
If you can, upload a pic so we could see your setup. I added 2” spacers after having the same issue. You mention spacers were already added, what’s the height?
Kostas
1984 Ski Nautique 2001 |
I dunno Pete, you turn 66 and........... well nevermind I think this is what you may have been thinking of link to recent post |
Webster
Best pic I could get spur of the moment..... You can see I've pretty much maxed out the spacing between trailer guides and the guard. |
