  New Posts New Posts RSS Feed - 90s CC trailer Boat Guides
Wtrskior View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wtrskior Quote  Post ReplyReply Direct Link To This Post Topic: 90s CC trailer Boat Guides
    Posted: June-06-2017 at 12:15pm
I posted a few weeks back about buying a TSC1 196.   It appears the trailer is actually a few years older, and may actually be a CC branded single axle unit. There are no boat guides, but rather holes where the guides should be.   I thought initially that they are threaded, but from asking around perhaps they were actually welded and broke off?
This appears to be the same trailer, with actual guides:
So I need to either build or buy new guides.    Does anyone have any insight on either of these avenues?
Here is my new boat/trailer:
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-06-2017 at 12:21pm
They bolt on. They curve as the go through the trailer step (~45deg) and have a flat plate welded to the round post, which is oriented vertically. 2 bolts go through that plate to a corresponding plate that is integral to the trailer. All 90-01 cc and Ramlin trailers I've worked on have been the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wtrskior Quote  Post ReplyReply Direct Link To This Post Posted: June-06-2017 at 12:28pm
Thanks, that's helpful.
Any idea how I can get my hands on a set?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-06-2017 at 12:34pm
You can try calling Ramlin to see if they can still make them (they'll make you order through a CC dealer) but otherwise you'll have to fab them yourself.
bamajeeps View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bamajeeps Quote  Post ReplyReply Direct Link To This Post Posted: June-06-2017 at 2:18pm
PM sent
velde99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote velde99 Quote  Post ReplyReply Direct Link To This Post Posted: June-25-2017 at 3:01am
If you can't find any- I have a couple sets.
