Hot Engine Restart Question |
JHadji
Groupie Joined: August-18-2006 Location: Pittsburgh, PA Status: Offline Points: 74 |
Posted: September-25-2016 at 7:15am |
Hi guys, I had a frustrating thing happen & was hoping someone had a piece of advice. I have an 88 2001 with the 351. It runs great but if I shut it off when it's hot (e.g., picking up a skier), it won't restart. If I try too long, it seems to becomes harder to turn over & eventually kills the battery. If I restart it immediately or let it cool off by idling, it doesn't seem to happen. Flooding the engine before restart seems to help. Seems like I've got some kind of vapor lock happening. Hasn't been a problem for 25 yrs, but now twice this year (grrrr).
1988SkiNautique2001
John, Fill us in on what you mean by the above. If you are advancing the throttle to get the engine to start, then I suspect the carb is dripping fuel flooding the engine. Advancing the throttle give the engine more air overcoming the excess fuel. Immediately after a hot shutdown, look down the throat of the carb and see if there's any fuel dripping. It sounds like you will need a carb rebuild. |
Nautiquehunter
Platinum Member Joined: December-31-2008 Location: Lake Lanier GA Status: Offline Points: 1010 |
Sounds like its time for a carb overhaul.
Hollywood
LOL. not vapor lock. Find someone to help you look a the carburetor. |
JHadji
Thanks - I'll take the advice and focus on the carburetor. It's been quite a few years since retuning for ethanol. Will let you know if it solves the problem
1988SkiNautique2001
frozenskier
Groupie Joined: September-19-2011 Location: northern ny Status: Offline Points: 102 |
I had an 89 w the same engine and same problem. Carb rebuild kit did the trick, wish I had done that much sooner.
JHadji
Thanks for corroborating that! Parts changing gets time consuming and expensive pretty quick. A new or rebuilt carb doesn't seem unreasonable at her age. I'm wondering...is it plug & play or is there more of an art? I've tinkered with them in old cars, but admit I'm scared of tuning one on the boat
1988SkiNautique2001
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10606 |
If it runs good, chances are you just need to get a carb kit and give it a cleaning and it'll only set you back about 40 bucks you could also splurge for a Holley book that gives carb rebuild steps and lots of pictures. There are several on the market. To get the right rebuild kit, you need to get the list number off the air horn on the carb The picture shows where to find it. The pictured carburetor is in a car, but the location of the list number is the same. You'll save a bunch of money and learn how these old carbs function and maybe have some fun doing it KenO |
