No spark on Silver Nautique |
Post Reply | Page <12 |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10641 |
Hi Andrew Good to hear You mention the rotor being slightly different. Does it press snugly in the magnet ring or is it kinda loose and sloppy. The reason I ask is because that kit (the 9-1581 comes with a rotor that fits snugly and most replacement type rotors for that distributor are a loose sloppy fit if you try to use them in the magnet ring.and your timing will fluctuate due to the sloppiness. They look the same but are slightly skinnier than the Pertronix rotor. Was it a complete kit or just a module you got for it? Just trying to save you some possible aggravation. KenO |
This picture shows 2 rotors for the prestolite clip down cap distributor. The top one you can get just about anywhere, it's a real sloppy fit in the Pertronix magnet ring and will wreak havoc on your timing. It's width in the center section is 0.9 inches. The Pertronix rotor that comes in the 9-1581 kit is on the bottom. At a glance, it looks the same but it's 0.95 inches wide and a good snug fit in the magnet ring. SkiDim mentions that you need the pertronix rotor if replacing the rotor in their EI kit but doesn't say why.............this is why. Pertronix rotor part number is 1581R |
andrewmarani
Senior Member Joined: May-31-2005 Location: Baltimore, MD Status: Offline Points: 210 |
I bought the pertronix kit. I did check the fit of the rotor when I first put it on because the new rotor looked different than the old one. I remember the new fit snug, but I will double check the fit.
Thanks for making sure. |
Builder
