  New Posts New Posts RSS Feed - Sherwood Pump parts
Sherwood Pump parts
illiniball2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote illiniball2000 Quote  Post ReplyReply Direct Link To This Post Topic: Sherwood Pump parts
    Posted: April-20-2015 at 7:04pm
Anyone have know if I can find a rebuild kit for a Sherwood pump off of a 289/Interceptor 1966 pump info
#P10700G
Thanks,
Brian
Beer is my friend
87 Dominique
Had 67 Starflite
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2015 at 7:08pm
Brian,
Are you looking for a minor or major kit? Google Depco pump or Jamestown Distributors. Both handle Sherwood. Getting a kit should not be a problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote illiniball2000 Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2015 at 7:18pm
I need bearings for shaft so I think I need the major. I will look at those two places and see what all is included. Thanks Pete
Beer is my friend
87 Dominique
Had 67 Starflite
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2015 at 7:25pm
Sherwood parts
I think Sherwoods for the most part use the same bearings,got mine on ebay for around 13ea
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2015 at 7:35pm
in this case they don't but if you can read the numbers on your old ones many times you can find them cheaper on ebay or a bearing supply
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2015 at 7:35pm
Brian,
If you do have a hard time getting the major kit, bearings and seals can be obtained from any power transmission distributor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote illiniball2000 Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2015 at 8:05pm
Thanks guys. I am going to try and source them instead of buying the Major kit at $283.00. I will if I have to but that sounds painful!😳
Beer is my friend
87 Dominique
Had 67 Starflite
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2015 at 8:09pm
Or check ebay for the parts,I just bought 2 oem seals for a g21 for 1750 ea with free shipping,got them in 3 days. The same seal at pump vendor is 27.59
