Bearing buddy won't fit |
BigAir
Senior Member Joined: March-01-2004 Location: Wis. Rapids, WI Status: Offline Points: 155 |
Posted: September-24-2014 at 7:37pm |
I noticed one of the Bearing Buddy's on my 89 Ski Nautique trailer was gone. I replaced the bearings, picked up a new Bearing Buddy, went to put it in and it appeared to be too small even though it is the same size as the other side. Then I noticed what appears to be a sleeve on the other side that looks like it's pressed into the brake drum. The Bearing Buddy then gets pressed into the sleeve. The problem is that sleeve is gone too. My local boat dealer has no idea what I'm talking about and the guys at etrailer.com were no help either. Does anyone know where I can find a replacement sleeve?
dochockey
Gold Member Joined: September-16-2009 Location: Colorado Status: Offline Points: 638 |
I have a used one you can have it if u want send me a address
skidim also has them |
1989 Teal Ski Nautique
1967 Mustang Harris Float Sunfish |
BigAir
That would be great. Thank you very much. I'll PM my address. Be sure to let me know what postage costs.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21108 |
If you guys could post pictures of what the heck you're talking about, that would be great. All of the cc trailers I've messed with have utilized fairly standard hub/bearing hardware, and use standard size bearing buddies. I haven't messed with the 5200lb (6-lug) stuff yet, but will be doing so in the near future.
SNobsessed
My '89 trailer has the 'through the spindle' grease zerk - the hub cap has a rubber disk that allows access to the zerk. Does your '89 not have the drilled spindle? If so, someone may have changed the axle.
BigAir
Sorry. Skip to the next post.
BigAir
Here is a picture showing what the other side looks like. Notice the sleeve inserted into the brake drum. This is what the side in question looks like. The sleeve is gone. My guess is that it's still bouncing down a road somewhere or possibly in someone's grill. There is a grease fitting on the spindle so I don't think that was ever replaced. |
SNobsessed
OK, now it makes sense. You really don't need bearing buddies, you just need a hub cap with rubber insert, like this.
CrazyCanuck
Senior Member Joined: July-21-2013 Location: Vancouver B.C. Status: Offline Points: 254 |
Can you not just get buddies for the diametre of the hub, and not use the sleeve?
https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRtW3vJrMHLdqBzndt9VX3oOpBuRopGlzKq9Ea7pAO7wnTuoD8E8g
JPASS
Looks like the EZ Lube spindles. If that's what they are then there's no need for a bearing buddy.
'92 Correctcraft Ski Nautique
jimsport93
Platinum Member Joined: February-20-2008 Location: Alpharetta Ga Status: Offline Points: 1749 |
Shop around some trailer shops or places like Northern Tool. There is a metal cap with a rubber plug that will fit over the end of the spindle/hub like in JPASS's picture. They do come in various diameters.
Had a bearing failure a few years back. Took me a while to find those metal caps, but I finally did. |
kytom2
Gold Member Joined: July-25-2007 Location: Maysville Ky Status: Offline Points: 698 |
Go to champion trailers, they have everything you will ever need.
Hollywood
Yes they are EZ lube spindles and the grease/dust caps with rubber plugs aren't that hard to find. It is a very common system and works wonderfully!
BigAir
Thanks for all the advice. You guys are incredibly helpful and a huge asset to all the Correct Craft enthusiasts out there.
