  New Posts New Posts RSS Feed - proper steering wheel removal
illiniball2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote illiniball2000 Quote  Post ReplyReply Direct Link To This Post Topic: proper steering wheel removal
    Posted: September-16-2014 at 9:41pm
Can someone tell me the proper way to remove this steering wheel from a 71 Baracuda? I don't want to damage it.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2014 at 9:51pm
Take a real close look where that center cap meets the hub you will see a wire clip,much like a circlip. Pull it out with a small screwdriver or a sharp awl. Once that's out the center cap will come off and you'll see the hub and the nut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote illiniball2000 Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2014 at 10:06pm
OK thanks I knew there had to be something I was missing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote illiniball2000 Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2014 at 10:21pm
Gary
It took less than two minutes to remove   Thanks again
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: September-16-2014 at 10:32pm
