To lube or not to lube....(prop taper) |
CrazyCanuck
Senior Member Joined: July-21-2013 Location: Vancouver B.C. Status: Offline Points: 254 |
Posted: July-04-2014 at 3:42am |
Hi all.
I bought myself a nice shiny new ACME puller today, and it worked like a charm. I put my prop on and ran the boat once this past month, and I couldn't budge it off without a puller. Now, I did not put any neverseize on the taper because I read Peter's great post about lapping and so on. However, the info that came with the puller says that a slight amount of grease or antiseize is acceptable. What are you all doing? Dry fit? Tiny bit of neverseize? Dab of grease? I searched but could not find a definitive answer. Thanks. Corey. |
https://encrypted-tbn1.gstatic.com/images?q=tbn:ANd9GcRtW3vJrMHLdqBzndt9VX3oOpBuRopGlzKq9Ea7pAO7wnTuoD8E8g
Orlando76
Interesting the instructions say to lube it. I was always told not too and never have. I'd rather have to use a puller than to have a prop fall off. Splined shafts I lube.
SNobsessed
-1 on the lube!
If the prop was stainless then it might want to seize. The prop is nickle - brass - aluminum, doesn't react with the stainless shaft. |
Corey,
I suggest no lube on the taper. Most of the torque from the shaft to the prop is transmitted via the taper. If a lube is used, then the torque goes to the prop via the key/keyway. A 1/4" key will not handle the torque load. The instructions that came with the prop may have been for the splined props. Take a look at them again and get to us. Yes, a puller is always needed on a properly fit/lapped prop. |
CrazyCanuck
I could take a photo of the instructions and post it, but have to run to work. Here is a typed quote....note step 5....
ACME MARINE GROUP PROP PULLER INSTRUCTIONS (for the traditional style puller-part #228S) 1. Remove the cotter pin. Loosen the prop nut two turns (do not remove the nut). You want approximately 2 full threads of space between the nut and prop hub. 2. Back out the prop puller bolt to allow for installation of the puller. The puller "fingers" slide between the forward end of the prop hub and aft of the strut. The puller bolt cap is positioned over the end of the shaft aft of the prop. 3. Advance the puller bolt clockwise with a wrench. Do not over-tighten. The purpose of tightening is not to break the prop free, but to apply ample pressure on the end of the shaft and the forward end of the prop hub to transfer the shock, during impact, with a hammer. 4. Once the puller is firmly in place and the puller is tightened down, hit the puller on the end opposite the bolt, with a hammer (it is also possible to hit the head of the puller bolt, hitting it on the finger end is preferred, to avoid causing damage to the bolt, cap or bolt threads). It may be necessary to repeat steps 3 & 4. The hammer impact and harmonics should be enough to break the prop free form the shaft taper. Once free, remove the nut prop, and key( if app). 5. When reinstalling the propeller, a very light film of grease or anti-seize on the shaft/bore taper is acceptable, but do not over-apply. Also do not over-tighten the prop nut. Approximately 35 foot pounds is sufficient. It does not say what type of taper splined or otherwise....weird. Corey. |
I must call Acme to discuss the issue!! I can't believe their instructions!!
lewy2001
Sounds like Quinner's tool box has another use
baitkiller
Just spit on it.
DayTony
Gold Member Joined: June-30-2013 Location: Salem MA Status: Offline Points: 830 |
I have always put them on dry,
But if it is a new prop it always helps to get some lapping compound and, spend a few minutes lapping it in, then wipe it down before installing. I do however put a little grease on the nut, a little on the threads and a little on the face of it will reduce friction and help it tighten up. |
Hollywood
Nobody ever heard of "don't believe everything you read" ?
Tim D
I just replace my original prop on my '01 Air. It had oil on the key and shaft. I got the slightest curl bend on the tip of one blade. I visited a pier I've never been to before. The only thing I can think of is while holding the boat in waist deep water, the prop hit a root riding down a roller coming in. When I left the pier I heard a new whirl sound, couldn't feel vibration though. No scratches, the patina not even messed up. I know I didn't hit anything while it was spinning. Any way, I guessed it came from the factory with oil.
Tim D
DayTony
If the prop is properly lapped in and there isn't any bronze left on the shaft taper i don't see where a light coat of oil will hurt. Its just going to squeeze out When its tightened up. I dont think i would use something heavy like grease though.
My prop shaft has(had) little pieces of bronze imbedded into the taper from the old wheel or previous failures so i had to chisel some of it off to get a proper fit. |
missicbc
Newbie Joined: September-16-2014 Location: Berlin Status: Offline Points: 4 |
The prop is nickle - brass - aluminum, doesn't react with the stainless shaft. Fifa 15 Coins
MrMcD
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3588 |
I lap my prop's in, then after cleaning the shaft and prop with soapy water and drying them I put a very thin wipe of marine grease on the contact points and the threads. After our recent accident I pulled the prop. I cranked hard on the prop puller and nothing. With the prop puller fully tensioned and the prop nut loose about 1/4 inch I hit the prop puller with a 2 lb ball pen hammer and the prop made a loud twang and popped loose. Based on the twang and very hard removal I think it seated just fine in spite of the light grease which helped with assembly and getting the prop lined up with the marks on the shaft.
I personally would suggest avoiding any lubricant since I don't want someone getting the idea that more is better and then over applying it. If you do use a lubricant, the lighter the better (10W) and only a very light film. I would not use grease as it may not completely squeeze out and prevent full contact with the taper surfaces.
Tim D
Mighty early in the morning to be talking about lubing your shaft.
Tim D
Kristof
Grand Poobah Joined: October-08-2007 Location: Bree, Belgium Status: Offline Points: 3390 |
Hollywood
For some of us that's just how we start our day.
baitkiller
Every day
