Craftlander boat lift |
seacamper
Platinum Member Joined: June-24-2010 Location: Florida Status: Offline Points: 1056 |
Posted: April-15-2014 at 3:20pm |
Since I feel that you are all my "spirit guides" when it comes to all things nautical, can anyone recommend a good boat lift for a 1989 SN with a possibility of going to a Air Nautique later? Can I use a 120" wide lift with docking guides? What is the minimum weight I should go to? I am looking at 4500lbs. How about the canopies? Anyone have the "tower canopy"?
Thanks Tom |
1980 Ski Nautique Boat Bar
1988 Mastercraft Tristar Open Bow 1988 Mastercraft Tristar Closed Bow 1969 Seacamper Houseboat 1986 Harris Pontoon 2004 Seadoo GTX SC + Flydive Xboard 1999 Adventurecraft |
IAughtNaut
Grand Poobah Joined: August-22-2010 Location: TN Status: Offline Points: 2568 |
I don't know anything about lifts but I love that every one of your post includes a subtle "My wife doesn't know I'm still thinking about upgrading to an Air" flavor
seacamper
Just as bad, she doesnt know I'm thinking about a lift!
Tom |
quinner
Hey Tom, was at Eddies last month over spring break, sorry I didn't get a chance to meet you then.
Regarding a lift, if you stick with a direct drive, a 4k lift should be fine. Up north Shorestation is the most common brand and makes a great product. Would definitely recommend going with a canopy, the vinyl needs to be replaced every 8-10yrs, lift cables may last a bit longer. If there is a possibility your secret future boat will have a tower it will be important that the canopy is height adjustable. Canopy works tower up or tower down when adjusted correctly, tower down will get it up tighter and provide more shade. |
seacamper
Thanks Chris, I will look for you next time! I am looking at the larger canopies that give the tower as much room as possible when it is folded down. When you were at Eddies, you might have seen my "dock to nowhere" that highlights the problems we have with our lake levels. I would prefer a nice stick built boathouse and dock, but I think the lift and canopy might be better in the long run for current and future secret boat. Tom |
4th ski-doo
Newbie Joined: December-20-2013 Location: Midwest Status: Offline Points: 34 |
Harbor Mater makes a nice canopy that opens higher on the lake side but provides nice coverage on the sides. With the tower you can lift the boat solid to get people out then drop the tower and raise the boat the rest of the way. 4,000 is close, a 210 dry specs out at 3,800 plus fuel and some water in the well you're there. I'm of the book overkill is better but the higher the lift weight the cost rises too.
I ran real close on my Harbor Master and broke a part once before getting the bigger lift. |
2013 SANTE 210
2011 Sport 200v 1994 Bimini Skier Pro 190 1987 Master Craft Power Slot |
quinner
Tom, if you think the lift will need to be moved at all look at how big the feet are and if they have a fair amount of rocker or bent ends, bigger feet will make them easier to move. Regarding the canopy what you want is a decent amount of side length which = shade, I set mine up so the boat would just be out of the water with the tower up and tight to the top, then with tower down it could crank way up and be well covered. Having a few extra feet in the length also makes a big difference for shade, + 4' to 6' of boat length is ideal.
seacamper
So guys, does it matter if I go with 108" 114" or 120" wide?
quinner
That could be brand dependent, you would want to confirm, if equipped with side rails, what is the actual distance between those. Ideally they would be at rub rail height while pulling on/off the lift, the newer the CC the wider that dimension. Would imagine the 120 would be best, that is what my SS is.
seacamper
Thanks Quinner.
I just confirmed with Craftlander on the 120 verses 108 thing. They recommended the 120 with the "mooring bunks" to guide the boat in. So I am getting the 4500lb 120" wide 64" lift with a 120" by 26' High Top "Tower" canopy. The High Top has.....well....a higher top and more vinyl, and the "Tower" option opens the frame on one end and has zippers. I also ordered the "Ski Bunk Risers" to lift the bunks enough to clear the tracking fins. Now, does $5700 sound too high? Tom |
