Intake/carb selection for 318 Chrysler |
Post Reply | Page <123 |
Author | ||||
74Wind
That is the house I meant. By apartment I meant at the Waterfront. the building on the north side where the bar/etc is used to be a garage on the roadside and an apartment on the lake side. Comically, the breakwall foundation was cracked/shifted then and on rough days the water would splash up under my bed...gave new meaning to "living on the water". |
1974 Southwind 18
1975 Century Mark II |
C-Bass
Platinum Member Joined: November-18-2008 Location: Columbus, IN Status: Offline Points: 1248 |
Okay, dragging this back from the dead to try and understand this Chrysler intake modification for taking an automotive intake (in my case Edelbrock Performer RPM) and making it work with the Chrysler marine cooling circuit. If Reid, or someone familiar with the specifics, could help me out in exactly how you go about modifying the intake. Was this welded? Epoxy? I have tried to sketch up the flow path and the location of the modification. Please correct me if I'm understanding this wrong, which is highly likely. Green - fresh water thru pump Yellow - Starboard side of block/head back to modified intake blockage, forcing back to front, across to port side Red - Port side of block/head, back to intake/thermostat, out to rear of exhaust manifolds. |
hawkeyes16
Newbie Joined: September-26-2016 Location: york uk Status: Offline Points: 6 |
hi just been reading your posts here please can anyone tell me the modification for the edlebrock intake that diverts the coolant flow out and into the front crossover device this is a key issue and would love to get the definitive answer thanks D
