mustang #1 pictures |
Post Reply | Page 123 4> |
farmer
Senior Member Joined: July-23-2006 Location: United States Status: Offline Points: 442 |
Posted: December-09-2006 at 10:16pm |
Watch your fingers.
bkhallpass
Looks like a good project. Everything's there. Have fun. BKH
Livin' the Dream
jbear
Speaking of having fun.................hows it goin' Brian? Denese and the little one doing ok?
john |
"Loud pipes save lives"
Randy_in_Ohio
farmer - that should be a nice winter project... I love the old Mustangs, what a cla$$ic! keep us updated with pics of your progress. I think a good cleaning would make a huge difference. it looks like it was left in the water. When i got mine i tried everything to clean the hull (muriatic acid, hull cleaner, etc.) found that Purple Power worked the best worked great cleaning the bilge too. $9.99 for 2.5 gal. at Autozone. Good Stuff!
BTW- next time you post pics try hitting the enter button after each pic post. when you put each pic post on it's own line it will stack them vertically instead of side-by-side. makes it a little easier to browse through. trying to help... Brian- hope your getting some sleep over there! |
farmer
Randy, thanks for the tip. I'll try it next time. I have more up to date pictures of my progress and also of the rigging I used to turn the boat over if anyone is interested. thanks again Farmer
Randy_in_Ohio
Turn the boat over??? How Why??
eric lavine
I had to go into the next room to finish reading those posts, what happened?? nice boat, nice lines
farmer
Randy in Ohio Here are a couple of pics of the gelcoat below the waterline. The entire bottom is like this so I felt the easiest way to work on it was to turn the boat over. Does anyone have any experience with gelcoat in this condition? Farmer
farmer
Help. why did the text stretch out so far past the pictures? Farmer
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5765 |
That's an easy one, your pics in the first post are all on the same line so they dictate the frame of the post window for all subsequent posts. All you have to do is put a carriage return(enter key) after each Picture when you're uploading them and the pics will line up vertically stacked shortening the window width. So your problem is not with the last post you made but with the first. I hope that makes sense |
farmer
Thanks.If I post anyhting else I'll start a new topic Farmer
David F
You got yourself a quit a project there. All complete, but you should consider removing all the gelcoat via grinding and painting the hull. Or, you can re-apply gelcoat if you are up to all the sanding involved.
Good luck and keep us updated. |
Randy_in_Ohio
Farmer-
I see now why you turned it over. Man, that looks like a lot of work. also seen the rig you used to flip it. pretty slick. Keep posting pics of your progress. |
farmer
David,do you have any experience with gelcoat removal etc?
You could say DavidF has a little bit of experience on the subject.
M3Fan
...and the 7 series in the garage shows that this guy doesn't fool around.
farmer
DavidF. That looks beautiful. Is that gelcoat or paint?
Its gel- DavidF doesnt mess around!
farmer
Hi everybody. I just realized I could edit my picture post after the fact to arrange them vertically. Duh....
Farmer |
David F
Yes, just a bit of experience The easiest way to remove the gelcoat is with a 4" or 4.5" grinder with a 36 grit pad. Do not be tempted to use a 7" grinder as it does not work nearly as well and the extra weight will wear you out more than twice as fast. When you get down to the fibergla$$, you could switch to a 7" grinder to help even out the fibergla$$ surface. You will then have to fair (fare?) the entire hull. Bondo is fine for fairing, or you can use thickened epoxy which is what I used as evident in the pictures above. |
farmer
Finally got to putting the epoxy bottom on my mustang.It took a long time to fair the bottom. I made the mistake of knocking off the edges because the fiberglass looked like it had crystallized and was brittle.DO NOT DO THAT.It would have been much better to leave the edges and just cover them with the epoxy.
farmer
Thought I'd repost the pictures that were lost.
farmer
Well here we are almost a year later and I finally got back at the Mustang.I'm in the process of sanding the epoxy bottom. The epoxy did not cure smoothly. It feels and looks like an eggshell texture. I don't know if it's something I did or what. So,I'm sanding with 80 grit(had to do it anyway for the bottom paint) I'm using the Interlux VC hard bottom paint with teflon.It comes in white so I'm hoping it won't be too noticeable that low on the sides. I still have to get all the old sealer out of the strut pocket so the base fits flush. I took off more thickness than I put back with the epoxy. Was it Lifetime caulk that some of you have used with good results? Farmer |
JoeinNY
Lifetime or 3M 5200 will both do the job as a sealant, the 5200 is a better adhesive but that is not always a good thing.
farmer
You're right,I should plan ahead alittle and use the lifetime in case I need to re-bush anything. |
Gary, I would go with the 5200 just because of it's adhesive qualities. Re bushing can be easily done on the boat. If you ever do need to remove the strut, that's a easy one too especially with the non recessed base type strut. Hot wiring works great. A piece of nichrome wire or even stainless mig wire hooked to a car battery cuts right through the 5200.
Since you removed more thickness on the bottom than what you put back on, you may need to add some stainless flat washers under the strut so the shaft bore in the strut will line up with the hole and log in the bottom of the hull. That's another good reason to go with the 5200. If the strut if off more than 1 thickness of a flat washer, I have used thickened epoxy under the strut to build up a base. Use a piece of wax paper when bolting the strut down into the epoxy so it doesn't stick. |
farmer
Pete,the base of this strut fits flush with the bottom of the boat.I just looked at the picture and realized that it doesn't look that way but there is a recessed area that the base fits into. So the alignment shouldn't be affected. would you still use the 5200 ? |
Gary, I would because I really like the 5200 and it's sealing. I worry about removal later! The recess I'm reffering to is the new boats where the whole strut base sits in a pocket molded in the bottom of the hull. If you can't get a hot wire under a strut, a torch can be used to heat the strut. I seem to remember that it only takes about 200 degrees to soften the 5200. That temp will not affect the temper of the bronze strut.
Did you catch my post about using a hard plastic bushing in place of the rubber cutlass as a temp means of using the prop shaft to line up the strut with the hole and log in the hull? Edit: I do see the recess now! Don't count on it being the same. Do check the strut to the hole alignment. |
Pete, would there be any harm in using 4200 instead? That would be easier to remove (someday) and still seal as well, correct?
82wake2001
Senior Member Joined: February-14-2008 Location: United States Status: Offline Points: 240 |
wow that is amazing Farmer.....wish i had those skills ....
