Rear hatch not opening |
TRIP
Gold Member Joined: December-08-2007 Location: Costa Rica Status: Offline Points: 629 |
Posted: February-15-2019 at 3:39pm |
Suspect it might be a relay. Anyone know where to find it on a '97 Super Sport?
Did you check for power at the actuator,they are known to go bad. On my boat you have the two on the ECM mount for the fuel pumps then there are two in the main harness right above where the shift cable connects to the trans shifting lever. I understand one of those is it,possibly one is for up,one for down?
TRIP
You're a star Gary!
Changed out the red and black on those relays and up went the hatch! Filled up motor oil (leaking seal so 5 hours is max what I can do without topping it off, and 5 hours I did since last check) and can serve clients tomorrow. Mil gracias! |
