  New Posts New Posts RSS Feed - Gas struts for '04 216 rear deck
Redelf75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redelf75 Quote  Post ReplyReply Direct Link To This Post Topic: Gas struts for '04 216 rear deck
    Posted: August-29-2018 at 4:17pm
Hi,
I changed the struts on my '04 Air 216 but because I couldn't read the stats on the existing ones, I bought 40lbs force which are way too weak. They hold up the lids if they're up already, but they can't push them up by themselves.
I'm guessing that 80 or 100lbs would work but wanted to ask if anyone knew what the correct force is?
Thank you,
Louis
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-29-2018 at 4:33pm
Originally posted by Redelf75 Redelf75 wrote:
Hi,
Thank you,
Louis
Scroll down towards the bottom of the page.
James T Brockma View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote James T Brockma Quote  Post ReplyReply Direct Link To This Post Posted: August-29-2018 at 8:46pm
I replaced all of my gas struts on my 2006 216 last year. If it would help you I would be happy to check the #’s on mine tomorrow or Friday and give you the specs.
Jim '06 216
    '98 SN 176
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redelf75 Quote  Post ReplyReply Direct Link To This Post Posted: August-30-2018 at 3:14pm
Thanks to both of you.
If it's not too much trouble, I'd like to know what you put in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redelf75 Quote  Post ReplyReply Direct Link To This Post Posted: August-30-2018 at 4:51pm
The link listed in the first reply indicates a 20lb strut for the ski locker. I installed a 40lbs one and find that way too weak. But thank you, the site is good know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: August-30-2018 at 6:23pm
Those are for the ski locker in the floor!! not your rear pads, go down the page there is some 60# ones those are the ones you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote James T Brockma Quote  Post ReplyReply Direct Link To This Post Posted: August-30-2018 at 8:49pm
The rear sun pad/ski locker struts on a 216 are 60 lbs. The print stamped on the strut says “ML36 60”.
The label glued to the strut says “ Gas Strut / 17.2 inches 60 lbs.
They stay up without issue.
I hope that helps
Jim '06 216
    '98 SN 176
Post Options Post Options   Thanks (0) Thanks(0)   Quote James T Brockma Quote  Post ReplyReply Direct Link To This Post Posted: August-30-2018 at 8:53pm
I also replaced the struts for the engine cover, observer’s seat and glove box.
Let me know if you need those #’s too.
Jim '06 216
    '98 SN 176
Post Options Post Options   Thanks (0) Thanks(0)   Quote James T Brockma Quote  Post ReplyReply Direct Link To This Post Posted: August-30-2018 at 8:55pm
Also... my in floor “ski locker/cooler” has no strut. It is just a removable carpeted floor panel.
Jim '06 216
    '98 SN 176
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: August-30-2018 at 10:56pm
Sports have a gas shock on the floor locker, at least the ones I’ve been looking at (99 - ‘03)
